Hello Guys :)
I'm having problem as described in a topic with a "Input string was not in a correct format".
Steps I'm doing:
Running VS2013 with admin priv.
Cloning repo from git
Building solution (everything's fine)
Running Umbraco.Web.UI
Exception (In a firefox a see only welcome picture of you guys :) But no install config boxes etc)
Machine config:
Windows 8.1 Pro
Visual Studio 2013 Update 3
Umbraco 7.1.6
Net 4.5
IIS 8.5
Full Control for : Network Service, IIS_IUSRS.
Path to Umbraco without white space. .Net 4.5 Integrated pool. Net Trust Level: Full(internal).
Umbraco Log:
2014-09-04 10:49:26,177 [9] DEBUG Umbraco.Web.UmbracoModule - [Thread
12] Begin request: http://localhost/Umbraco.Web.UI/. 2014-09-04
10:49:26,179 [9] INFO Umbraco.Web.UmbracoModule - [Thread 12] Setting
OriginalRequestUrl: localhost:80/Umbraco.Web.UI/umbraco 2014-09-04
10:49:26,340 [9] DEBUG Umbraco.Web.UmbracoModule - [Thread 12] Begin
request: http://localhost/Umbraco.Web.UI/. 2014-09-04 10:49:26,343 [9]
DEBUG Umbraco.Web.UmbracoModule - [Thread 12] Begin request:
http://localhost/Umbraco.Web.UI/default.aspx. 2014-09-04 10:49:26,352
[9] INFO Umbraco.Core.ApplicationContext - [Thread 12] CurrentVersion
different from configStatus: '7.2.0','' 2014-09-04 10:49:26,355 [9]
WARN Umbraco.Web.UmbracoModule - [Thread 12] Umbraco is not
configured 2014-09-04 10:49:26,416 [9] DEBUG Umbraco.Web.UmbracoModule
- [Thread 23] Begin request: http://localhost/Umbraco.Web.UI/install/?redir=true&url=http:%2f%2flocalhost%2fUmbraco.Web.UI%2fdefault.aspx.
2014-09-04 10:49:26,460 [9] INFO Umbraco.Core.ApplicationContext -
[Thread 23] CurrentVersion different from configStatus: '7.2.0',''
2014-09-04 10:49:27,589 [9] DEBUG Umbraco.Web.UmbracoModule - [Thread
11] Begin request:
http://localhost/Umbraco.Web.UI/umbraco/assets/css/installer.css.
2014-09-04 10:49:27,595 [9] DEBUG Umbraco.Web.UmbracoModule - [Thread
20] Begin request:
http://localhost/Umbraco.Web.UI/umbraco/lib/lazyload/lazyload.min.js.
2014-09-04 10:49:27,596 [9] DEBUG Umbraco.Web.UmbracoModule - [Thread
21] Begin request:
http://localhost/Umbraco.Web.UI/umbraco/assets/img/application/logowhite.png.
2014-09-04 10:49:27,637 [9] DEBUG Umbraco.Web.UmbracoModule - [Thread
14] Begin request:
http://localhost/Umbraco.Web.UI/umbraco/assets/img/installer.jpg.
2014-09-04 10:49:27,639 [9] DEBUG Umbraco.Web.UmbracoModule - [Thread
17] Begin request:
2014-09-04 10:49:27,757 [9] DEBUG Umbraco.Web.UmbracoModule - [Thread
23] Begin request:
http://localhost/Umbraco.Web.UI/_browserLink/requestData/7ab9fa191f534dfab5d97d57581c91aa?version=2.
2014-09-04 10:49:27,838 [9] ERROR Umbraco.Core.UmbracoApplicationBase
- [Thread 23] An unhandled exception occurred System.FormatException: Input string was not in a correct format. at
System.Text.StringBuilder.AppendFormat(IFormatProvider provider,
String format, Object[] args) at
System.String.Format(IFormatProvider provider, String format, Object[]
args) at
Microsoft.VisualStudio.Web.PageInspector.Runtime.MappingData.MappingDataUtilities.GenerateSelectorsForElementsWithTagName(List1
elements, RenderedElement referenceElement, SelectorReferenceType
referenceType, String selectorFormatString, SelectorGroupFunction[]
groupMethods, Int32 startIndex) at
Microsoft.VisualStudio.Web.PageInspector.Runtime.MappingData.MappingDataUtilities.GenerateSelectorsWorker(IEnumerable1
groupMethods) at
referenceType, SelectorGroupFunction[] groupMethods) at
Microsoft.VisualStudio.Web.PageInspector.Runtime.MappingData.MappingDataUtilities.GenerateSelectors(IEnumerable1
elements) at
Microsoft.VisualStudio.Web.PageInspector.Runtime.MappingData.MappingDataUtilities.ProcessDataIntoJsonObjects(IEnumerable`1
renderedOutputList, Boolean legacyJsonObjects) at
Microsoft.VisualStudio.Web.PageInspector.Runtime.Tracing.RequestDataHttpHandler.System.Web.IHttpHandler.ProcessRequest(HttpContext
context) at
System.Web.HttpApplication.CallHandlerExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute()
at System.Web.HttpApplication.ExecuteStep(IExecutionStep step,
Boolean& completedSynchronously)
I used NuGet package once, and it worked like a charm, but I can't get it working from sources :/ I tried to give you as much info as it seemed important to me. Please tell me if anything more is required.
Problem with installing Umbraco from sources using VS2013
Hello Guys :) I'm having problem as described in a topic with a "Input string was not in a correct format".
Steps I'm doing:
Machine config:
Full Control for : Network Service, IIS_IUSRS. Path to Umbraco without white space. .Net 4.5 Integrated pool. Net Trust Level: Full(internal).
Umbraco Log:
nobody have a clue? I fight with it for a few days now... :( Really wanted to start some coding in it ;((
