  • Kate 267 posts 610 karma points
    Sep 02, 2010 @ 11:30
    Kate
    Need help making macro works
    Hello
    I need a little help with something I think is very basic in umbraco.
    I'm reading this article: http://umbraco.org/documentation/books/xslt-basics/what-is-xslt and follow his examples. I just can't get it to work :-(
    I created an xslt which contain the following:
    <! - Start writing XSLT ->
      <xsl:value-of select="$currentPage/@nodeName"/> <br/> <br/>
      Text: <xsl:value-of select="$currentPage/data[@alias='website']/text()"/>
    There is automatically created a macro.
    Under Settings, I've created a Document Type (plaintext) where I've created a property with the following:
    Alias: website
    Type: Richtext editor
    Tab: content
    On my page under the tab "content", I have added some text.
    And on my template (under Setings), I have added my macro. Looking like this:
    <%@ Master Language="C#" MasterPageFile="~/umbraco/masterpages/default.master" AutoEventWireup="true" %>
    <asp:Content ContentPlaceHolderID="ContentPlaceHolderDefault" runat="server">
      <umbraco:Macro Alias="Xxx" runat="server"></umbraco:Macro>
    </asp:Content>
    My problem is that I dont get any text displayed on the page.
    What am I doing wrong?
    Am I missing some settings?
    I look forward to hearing your reply.
  • Bijesh Tank 192 posts 420 karma points
    Sep 02, 2010 @ 11:33
    Bijesh Tank
    Hi Kate,
    Which version of Umbraco are you using?
    Regards,
    Bijesh
    Sep 02, 2010 @ 11:35
    Kate
    I´m using umbraco v 4.5.1
    Sep 02, 2010 @ 11:37
    Bijesh Tank
    You might to check what template your document type is using and make sure that your content page has the template set under Properties tab
    Sep 02, 2010 @ 11:45
    Kate
    I think all that is okay, because in my xslt I have written the word "Text" and that is displayed on my page.
    Sep 02, 2010 @ 11:49
    Bijesh Tank
    Also, 4.5.1 uses the new XML schema, so the XSLT examples you were looking at are slightly out of date (for older version of Umbraco, 4.0.x).  Here's a reference how to use the new schema with some example:
    http://our.umbraco.org/wiki/reference/xslt/45-xml-schema/xslt-examples-updated-to-new-schema
    Sep 02, 2010 @ 11:51
    Kate
    thanks
    I will have a look at it and then I will probably get back to you :-)
    Sep 02, 2010 @ 12:02
    Kate
    I found this:
    <xsl:value-of select="$currentPage/* [name() = $myMacroParameter and not(@isDoc)]" />
    but ofcause it gives me an error.
    The "$myMacroParameter" I don´t know what to do with.
    Is there some settings I need to change in the Macro
    And what about [name(). What does that means?
    Sep 02, 2010 @ 13:08
    Bijesh Tank
    So, instead of:
    Try:
    <xsl:value-of select="$currentPage/website"/>
    Sep 02, 2010 @ 13:14
    Kate
    It works - kind of :-)
    It writes my html on the page as well:
    http://shiftumbraco.planetshift.dk/1313.aspx
    Sep 02, 2010 @ 13:18
    Bijesh Tank
    Ah, add disable-output-escaping - so it would be
    <xsl:value-of select="$currentPage/website" disable-output-escaping="yes"/>
    Sep 02, 2010 @ 13:23
    Kate
    Jubii, it works
    So I dont have to think about if it is at Node or Data that Im getting my data from?
    Thanks for your help
    Sep 02, 2010 @ 13:44
    Bijesh Tank
    Glad you got it working :)
    Using the new XML schema makes it easier to work with.
