  • Arun 12 posts 42 karma points
    May 20, 2013 @ 12:48
    Arun
    Am going to use umbra co solution in My portal is it helpful?
    Dear friends,
                          Here i need to use adverticement in leftside , vedio in right side , top level also i need to mix adverticement and vedio , that also keep on change due to user prespective. is it ,all portal solution things i can achive from this CMS ? Please help me frinds.
    May 20, 2013 @ 13:32
    Hi Arun and welcome to our :)
    In short yes, Umbraco can help you achieve the above things.
    If you need further advice you probably need to be a bit more specific about what it exactly is you're going to build and where data is supposed to come from. Will it all be fed from Umbraco or do you need to make some 3rd party integration etc.?
    And are you going to be developing the site yourself or do you have some developers who should be doing it for you?
    Jan
    May 20, 2013 @ 14:08
    Arun
    Hi jan
                This am going to develop jan,. Acatually we are not started this one. I got an idea to do like this . and one more doubt is there jan? which .net framework
    is going to be support your Umbraco solution? Here i am using framework 3.5. Can u give a good suggestion? which frame work i have to use for this one? etc..
    Thanks  & Regards
    Arun
