  • pnr 131 posts 226 karma points
    Nov 17, 2009 @ 09:51
    pnr
    Problem with macro's in content
    I am making a replace of the content when i render it (thanks too dandrayne :-))
    But if i have some macro's in my content the macro will not show. Can anyone tell me what the problem is?
    Thanks in advance!
    <!DOCTYPE xsl:stylesheet [ <!ENTITY nbsp "&#x00A0;"> ]>
    <xsl:stylesheet
    version="1.0"
    <xsl:template match="/">
    <xsl:variable name="replaceThis">
    <xsl:text>class="nofollow"</xsl:text>
    </xsl:variable>
    <xsl:variable name="replaceWith">
    <xsl:text>rel="nofollow"</xsl:text>
    </xsl:variable>
    <xsl:value-of select="umbraco.library:Replace($currentPage/data[@alias='bodyText'], $replaceThis, $replaceWith)" disable-output-escaping="yes" />
    </xsl:template>
    </xsl:stylesheet>
  • Christian Palm 278 posts 273 karma points
    Nov 17, 2009 @ 09:59
    Christian Palm
    You need to call umbraco.library:RenderMacroContent(string Text, int PageId)
    <xsl:value-of select="umbraco.library:RenderMacroContent(umbraco.library:Replace($currentPage/data[@alias='bodyText'], $replaceThis, $replaceWith), $currentPage/@id)" disable-output-escaping="yes" />
    Nov 18, 2009 @ 10:59
    pnr
    Thanks very much!
