  • Anton 135 posts 186 karma points
    Mar 30, 2016 @ 16:34
    Anton
    How to add multi media picker to grid layout?
    How to add multi media picker to grid layout? how I can create custom editor for adding a lot images there?
  • Dennis Adolfi 1082 posts 6450 karma points MVP 6x c-trib
    Mar 31, 2016 @ 06:51
    Dennis Adolfi
    Hi Anton!
    A quick way of solving this (if your Grid editor allows macros) is to create a Gallery macro. The best about that is that there´s already a snippet for a Gallery that you can use:
    Create a new macro partial "Gallery" and choose snippet "Gallery", and remember to tick the box "Create macro".
    Go to the macro and tick the box "Use in rich text editor and the grid, and go to tab "Parameter". Add a new parameter with alias "mediaIds" and Type "Multiple Media Picker".
    Now, in your grid, Insert a macro and select the Gallery macro, then you can select the images from your Media section:
    Its not a Custom ediotor, but another way of solving it. Hope that it helps. Have a great day!
    Mar 31, 2016 @ 07:52
    Anton
    Thank you!) I will try
    Mar 31, 2016 @ 07:58
    Dennis Adolfi
    Awsome! :)
    Good luck with the rest of your Umbraco site and have a great day!!
  • Pedro Adão 43 posts 80 karma points
    Oct 04, 2016 @ 16:18
    Pedro Adão
    Thanks! You just saved my day! =)
    Oct 05, 2016 @ 06:15
    Dennis Adolfi
    Glad i could be of help Pedro! :)
    Have a great day!
