  • Martin 278 posts 662 karma points
    Apr 11, 2016 @ 07:36
    Martin
    7.4.2 + Visual Studio build error
    Hi, Im trying out 7.4 for the first time and Im getting a Compilation Error when I build from VS.
    Ive only just setup the project through Nuget and created a Master template and a child Home Doc & Template.
    It was working and I was getting a website showing, until after I run a build in VS I got the following YSOD.
    Compiler Error Message: CS0234: The type or namespace name 'Home' does not exist in the namespace 'Umbraco.Web.PublishedContentModels' (are you missing an assembly reference?)
    Source Error: public class PageViewsHomecshtml : Umbraco.Web.Mvc.UmbracoTemplatePage
    Any ideas would be grateful.
    Martin
    Apr 11, 2016 @ 08:01
    Martin
    Sorry, this is a templating issue.
    Is there a reason why the default worked for a while and then broke when I build from VS.
    This is the default ~@inherits when I create the doc & template. @inherits Umbraco.Web.Mvc.UmbracoTemplatePage
    @using ContentModels = Umbraco.Web.PublishedContentModels;
    Ive changed it back to the previous @inherits method and it works ok.
