Error message "Guid should contain 32 digits with 4 dashes"
I have a production site running Umbraco 7.4.1 (upgraded from 7.2.4), which is running fine after upgrade.
There also exists a staging site (which was running 7.2.4), but have uploaded same source code used in production to staging site and ran the upgrade installer, which successfully upgraded the site to 7.4.1
However on e.g. front page it is using grid editor with LeBlender, but instead of images, I get error messages
Guid should contain 32 digits with 4 dashes (xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx)
I checked the selected media items, which does have GUID keys. I also recycled the application pool and restarted the website.
Any idea why I get these errors?
When I upgraded the production site from 7.2.4 to 7.4.1 I didn't had these errors.
I restore the database from the production site to staging, which solved the issue. Not sure what the issue was - maybe some references were not correct or missing. It was only on in frontpage grid I had this issue though.
Any idea why I get these errors? When I upgraded the production site from 7.2.4 to 7.4.1 I didn't had these errors.
/Bjarne
