I have a partial view macro file which is my search feature which works really well displaying the found node details, i want it to also display the first image from the multimedia picker for that node and having trouble getting it working!
Here is the snippet of code that pulls/displays the node data, the multimedia field alias is 'images' could someone help!
<table cellpadding="10" cellspacing="5" style="width:98%;">
<tr>
<th>
Deal Name
</th>
<th>
Price
</th>
<th>
Holiday Dates
</th>
<th>
Detail
</th>
<th></th>
</tr>
@foreach (Node c in listDeals)
var link = Umbraco.Url(c.Id);
var sDate = c.GetProperty("startDate").Value;
var beginDate = umbraco.library.FormatDateTime(sDate, "d - ");
var eDate = c.GetProperty("endDate").Value;
var endingDate = umbraco.library.FormatDateTime(eDate, "d MMMM yyyy");
<tr>
<td>
@c.GetProperty("name").Value
</td>
<td>@c.GetProperty("price").Value</td>
<td>@{@beginDate @endingDate}</td>
<td>
@Html.Raw(c.GetProperty("mainText").Value)
</td>
<td><a class="pSubmit" href="@{@link}">
View Deal</a><td>
</tr>
</table>
Ok, you really don't want/need to be using the old NodeFactory, I've had a quick go at updating your code to use the current methods and added what I think your after with the image:
URGENT! Split multi media picker, display first image - partial view macro
Hey all,
Hi Peter,
How are you creating/setting the listDeals variable?
Jeavon
Here's the full code buddy if that helps
Hey thanks for that! seems to be having trouble though just getting error loading partial view script.
Seems to be with this line
If i remove it loads fine again just obviously without the image!
cheers
Strange, try this instead:
Still wouldn't load oddly?
Have managed to do it using my previous version but i cant figure out how to just use the first image found in the split, any advice on that?
heres the snippet:
Did it show an error?
You should almost never use a management service in a front end view such as MediaService!!
