  • Biagio Paruolo 1621 posts 1914 karma points c-trib
    Apr 27, 2016 @ 13:10
    Biagio Paruolo
    Grid: using with UIKit
    How to setting up the grid layout to use UIKIT or Foundation and not Bootstrap?
    Thanks.
    Apr 27, 2016 @ 13:16
    Dennis Aaen
    Hi Biagio,
    Try to have a look at the package umbraco-grid-renderers https://our.umbraco.org/projects/developer-tools/umbraco-grid-renderers/
    In this package you will get the grid layout, using different types of frameworks including Foundation and others.
    Foundation
    Responsive
    Skeleton*
    Gumby
    SolidGrid
    Skel
    You can also make your own grid, and called in the template like this https://our.umbraco.org/documentation/getting-started/backoffice/property-editors/built-in-property-editors/Grid-Layout/Render-Grid-In-Template
    Hope this helps,
    /Dennis
  • Nik 1625 posts 7295 karma points MVP 8x c-trib
    Apr 27, 2016 @ 13:17
    Nik
    Hi Biagio,
    In your Umbraco solution, under Views there is a Partials directory. In the Partials directory, there is a folder called Grid. In here (I advise using one of the existing templates as a guide) you can create your own grid rendering partial views using what ever CSS framework you like.
    Your main site then just needs to include the appropriate CSS and hey presto you have a non-bootstrap grid.
    You can render your grid in the same way you would normally, but just add the name of the partial view as an argument to the GetGridHtml method.
    Nik
    Apr 28, 2016 @ 13:36
    Biagio Paruolo
    I'll give a try.
