Error when logging out after authentication cookie expired
When a member clicks the logout button on our website after their authentication cookie has expired (for example, they left the web page open without interaction for an hour), a YSOD is displayed with the message "This type of page is not served"
The logout code itself is in a partial view and uses the UmbLoginStatusController as in the following code:
var loginStatusModel = Members.GetCurrentLoginStatus();
@if (loginStatusModel.IsLoggedIn)
var logoutModel = new PostRedirectModel();
logoutModel.RedirectUrl = "/";
using (Html.BeginUmbracoForm<UmbLoginStatusController>("HandleLogout"))
<li class="logout-li">
<button class="logout-button">Logout</button>
</li>
@Html.HiddenFor(m => logoutModel.RedirectUrl)
Does anyone know what is causing this and whether there is a solution?
Steve
Im having a similar problem, has anyone found any solution to this yet?
Nathan
After some more digging I still can't find any way around it? anyone got a solution to it or are you able to point me in the right direction?
Nathan
