  • Kasun 8 posts 77 karma points
    May 12, 2016 @ 12:41
    Kasun
    Bracket syntax for dynamic property
    I have a Form which contains a hidden field. I want to set a property to it's default value as, the Current page's (where the form is) dynamically generated property.
        var umbNode = new umbraco.presentation.nodeFactory.Node(Convert.ToInt32(Umbraco.Field("selectOrganization").ToString()));
        string propValue = umbNode.GetProperty("orgName").Value;
    I am able to set a value which is in the Document type properties (using [#alias] syntax)
    but I can't set the "propValue" to the hidden field default value..
    appriciate your help on this..
    thanks
  • Manish 373 posts 932 karma points
    May 12, 2016 @ 12:58
    Manish
    Hi Kausan
    Are you able to get the value in string type variable propValue and want to set this value in hidden field right ? or something else, please clear this.
    May 12, 2016 @ 13:03
    Kasun
    Hi Manish,
    Yds..I can get the value to the variable..just want to set it to the hidden field...
    May 12, 2016 @ 13:04
    Manish
    <input type="hidden" value="@propvalue" />
    is this not working for you
    Manish
    May 12, 2016 @ 13:09
    Kasun
    Hi Manish
    I cant use it because its a Umbraco Form and its rendering as a macro.. thats why I m tring to use the Form's hidden field and bracket syntax
    Kasun
    May 12, 2016 @ 13:13
    Manish
     @Html.HiddenFor(x => Model.FormId)
    use this one
    May 12, 2016 @ 13:17
    Kasun
    Hi Manish
    Ill try and let you know
    Thanks Kasun
