  • Dan Roddis 57 posts 241 karma points
    May 17, 2016 @ 13:56
    Dan Roddis
    Macro rich text editor problems when dirty in Umbraco 7.4.3
    Hi everyone,
    We use a Rich Text Editor macro data type in our Umbraco install to allow for Rich Text on macros.
    When you first enter the macro everything works as expected, however if you re-enter the macro following any kind of amendment trying to set the style or format causes the macro slide in dialog to close.
    This behavior is new to 7.4.3 so I'm guessing the click is hitting the overlay that should close the dialog rather than specific style / formatting the user is trying to enable within the Rich text editor - although seemingly only when that macro is 'dirty'
    I've raised http://issues.umbraco.org/issue/U4-8418 but would appreciate if anyone has any advice or workarounds for the issue?
