  • Aki 43 posts 214 karma points
    Jun 02, 2016 @ 06:40
    Aki
    Document type. property data is missing.. Help debugging
    Hello Im working on a Webpage on in a Dev enviornment. we are using U-sync..
    It's been working fine for a while but last update we did resulted in the Property data got lost. well its still on the front end..
    but the data is missing in the backoffice.
    its just showing the "Choose a layout for this section". if i create a new document it has the data.
    it should be mentioned that i created the Grid elements with plugins.
    have been looking for a reason but its beyond me why its not there anymore..
    i'm looking for help to debug this issue
    thanks Aki
  • Manish 373 posts 932 karma points
    Jun 02, 2016 @ 07:14
    Manish
    Hi Aki
    1. Clear app data folder
    2. Regenerate properties using 'Zu' builder. enter image description here
    3. Check properties inside Builder.cs
    Manish
    Jun 02, 2016 @ 09:47
    Aki
    Zu builder ?
    I need a better description please :)
    Have been looking through my project and google but i cant find 'Zu' Builder So a little bit more info would be nice :)
    Jul 03, 2016 @ 11:11
    Alex Skrypnyk
    Hi Aki,
    Zbu Model builder - https://github.com/zpqrtbnk/Zbu.ModelsBuilder
    Now it's part of the core.
    THanks,
    Alex
