Problem with Instagram Script and Placeholder Image
Hi all! I recently inherited a website for my organization that was created ~4 years ago by an outside agency that is no longer in business. I've only been involved with the project for a month or so now. Today, I noticed that our Instagram script on our front page is no longer working. The script is set to pull and display the latest image from our account, which it did just last week. No one's touched any of the codes, but there's definitely a weird placeholder photo there now that shouldn't be there.
Our base is below, which references the the script in question at the bottom:
This is a lot of information, but I honestly can't figure out why it's not working correctly anymore. I assume it's super obvious and I just can't see it, but nonetheless, here we are.
This is actually not an issue with your code unfortunately :(. All of our projects using Instagram also stopped working the other day. It was actually a restriction point in place by Instagram a while back but only put into affect on the first of June. Spinet from their dev site:
Any app created before Nov 17, 2015 will continue to function until
June 1, 2016. On that date, the app will automatically be moved to
Sandbox Mode if it wasn't approved through the review process. The
previous version of our documentation is still available here.
Oh wow, thank you so much! I didn't even think of that! There were two versions of this script that were up in umbraco when I started a few weeks ago, and I didn't even think to check when they were created. Would you be able to point me in the direction of another script I could use to replace the outdated one on the website?
And here is the script:
The placeholder image that's being queued is here:
Thanks!
Hey kresides,
https://www.instagram.com/developer/
You can try and put the account up for review, but by the sounds of it, it will be unlikely it will be approved unless there is real need.
Hope this information helps, Jordan
Hi Jordan,
Thanks!
