  • Sean Håkansson 68 posts 204 karma points
    Jun 20, 2016 @ 10:07
    Sean HÃ¥kansson
    Alternative view with custom routing
    Hi all, I'm playing around with alternative views is it possible to do altTemplate but with custom route? For example http://www.com/apple-pie/ renders normal view, and http://www.com/amp/apple-pie/ renders a different one? (I also want logic to check if document type supports this alternative markup).
    If anyone have experience with the amp project, what's the recommended URL structure for amp urls, maybe use query string instead?
    Dec 26, 2016 @ 21:48
    Alex Skrypnyk
    Hi Sean,
    I don't see any reasons why you can't do that.
    Just add rewriting rule for all rules with /amp/ to url with ?altTemplate=test
    If you need to check document type and supported views before render - then you need custom URL Rewrite Module
    Alex
