  • Thomas Park 3 posts 73 karma points
    Jun 21, 2016 @ 09:31
    Thomas Park
    Navigation with Sub Menus
    Hi Guys,
    This is a bit of a simple question but I'm only looking for pointers.
    I have got the following code which is the basic Navigation Menu. I want to
      So I want this navigation to load the following menus up;
      1) Home 2) Menu1 2.1) SubMenu1 2.2) SubMenu2 3) Contact
      Would I just need to add into the code a section that would check if there was a child and then list all the child items?
      As I stated at the start I only wont pointers/constructive help.
      Kind Regards, Tom
  • Alex Skrypnyk 6182 posts 24283 karma points MVP 8x admin c-trib
    Jun 21, 2016 @ 14:18
    Alex Skrypnyk
    Hi Tom,
    Umbraco tree traversing documentation here - https://our.umbraco.org/documentation/reference/templating/mvc/querying
    Are you familiar with Razor?
    Render menu is pretty easy, something like:
    @foreach (var item in rootNode.MainNavigation) {
  • @item.Name
    Alex
Copy Link
    Mar 01, 2017 @ 12:28
    Thomas Park
    Hi Alex,
    Thank you for the link, that has been helpful for this. I have now made the following which works well, I just need to update it for Bootstrap. I thought this might be useful for anyone else that is looking for something similar.
     @foreach (var childPage in home.Children)
            if (childPage.Children.Any())
                <li class="has-child @(childPage.IsAncestorOrSelf(CurrentPage) ? "selected" : null)">
                    @if(childPage.Children.Any())
                        <span>@childPage.Name</span>
                        @childPages(childPage.Children)
                    } else {
                        <a href="@childPage.Url">@childPage.Name</a>
                </li>
            else
                <li class="@(childPage.IsAncestorOrSelf(CurrentPage) ? "selected" : null)">
                </li>
    I have noticed that the Parent of any sub pages is not a link, I am going to have a go at fixing this and will post updated code later..
    Copy Link
  • Please Sign in or register to post replies
