  • Tim C 161 posts 528 karma points
    Jun 22, 2016 @ 11:46
    Tim C
    Error using Umbraco.TypedMedia in @functions
    In a partial view, I am listing documents within a foreach loop.
    However, I am parsing the values and making some alterations via some classes in a @functions{ section.
    Within the @functions{ section I can't seem to be able to use
    Umbraco.TypedMedia
    in a class eg
    public class rowOutput{
     private string fetchPropertyValue(
    int mediaId = Int32.Parse(pValue);
        var media = Umbraco.TypedMedia(mediaId);
      pValue = media.Url;
    returns error
    CS0038: Cannot access a non-static member of outer type 'Umbraco.Web.Mvc.UmbracoViewPage<Umbraco.Web.Models.RenderModel>' via nested type 'ASP._Page_Views_Partials_Listings_GenericSearch_cshtml.rowOutput'
    I'm hazy as to that this error means. Is there any way round this?
    Jun 22, 2016 @ 11:56
    Alex Skrypnyk
    Hi Tim,
    What about '@inherit' attribute of your view? Can you show? Do you use some custom serverside controller?
    Jun 22, 2016 @ 11:57
    Tim C
    It's not a custom controlled just a standard partial view.
    Jun 22, 2016 @ 11:59
    Alex Skrypnyk
    This problem with inheriting in master and your view, or maybe some custom logic in controllers. Do you have the same inherits attribute in your views?
    Jun 22, 2016 @ 12:01
    Tim C
    Do you mean the template : I am not working in Visual Studio, these are just templates and partial views in the Umbraco backoffice.
    Jun 22, 2016 @ 12:04
    Alex Skrypnyk
    Yes, can you show all your view ?
    Jun 22, 2016 @ 12:06
    Tim C
        Layout = "Master.cshtml";
    @section closeBody{
        </body>
                        <!-- main article list -->
                    @Html.Partial("Content/HomePageNews",
                                  new ViewDataDictionary {{"userNewsCategories",sUserNewsCategories},{"newsCount",5},{"showPagination","false"},{"showViewAll","1"}}
    Jun 22, 2016 @ 12:07
    Tim C
    Inherited from master...
    @using ContentModels = Umbraco.Web.PublishedContentModels
    @using Umbraco.Core.Security
    @using Umbraco.Core.Models.Membership
        Layout = null;}
    Jun 22, 2016 @ 12:11
    Alex Skrypnyk
    Not clear what the problem. It's typical error when rendering with wrong inherits attribute.
    Jun 22, 2016 @ 12:12
    Tim C
    What if I tried putting some c# in app_code to do the conversion from media id to media url : what namespaces would I need?
    Jun 22, 2016 @ 12:18
    Alex Skrypnyk
    You need Umbraco context helper.
    Jun 22, 2016 @ 12:35
    Alex Skrypnyk
    Are you using static class?
    Jun 22, 2016 @ 13:48
    Tim C
    Managed to find a work around by adding code to App_Code
    public static string getMediaUrl(int mediaId){
                umbracoHelper = new Umbraco.Web.UmbracoHelper(Umbraco.Web.UmbracoContext.Current);
                return umbracoHelper.TypedMedia(mediaId).Url.ToString();
