I am writing a partial view as below
@helper test {
hello
@test test
When I add this partialView to a page the word hello never shows? What am I doing wrong?
Hi Bob,
Take a look at this blog from ScottGu that explains the helper method syntax:
http://weblogs.asp.net/scottgu/asp-net-mvc-3-and-the-helper-syntax-within-razor
In your example if you want to display the hello text you could something like:
@helper SayHello() { <p>Hello!</p> } @SayHello()
/Michaël
Help with partialview code
@helper test {
hello
@test test
Hi Bob,
/Michaël
