  • Jon 47 posts 290 karma points
    Jul 19, 2016 @ 14:40
    Jon
    Very slow first visit and crashes sometimes
    Im having problems with very slow first visits and the site also crashes now and then...
    It says:
    Cannot bind source content type Umbraco.Web.PublishedContentModels.Frontpage to model content type Umbraco.Web.PublishedContentModels.Master. Types come from two PureLive assemblies with different versions, this usually indicates that the application is in an unstable state. The application is restarting now, reload the page and it should work
    Exception Details: Umbraco.Web.Mvc.ModelBindingException: Cannot bind source content type Umbraco.Web.PublishedContentModels.Frontpage to model content type Umbraco.Web.PublishedContentModels.Master. Types come from two PureLive assemblies with different versions, this usually indicates that the application is in an unstable state. The application is restarting now, reload the page and it should work.
        [ModelBindingException: Cannot bind source content type Umbraco.Web.PublishedContentModels.Frontpage to model content type Umbraco.Web.PublishedContentModels.Master. Types come from two PureLive assemblies with different versions, this usually indicates that the application is in an unstable state. The application is restarting now, reload the page and it should work.]
       Umbraco.Web.Mvc.RenderModelBinder.ThrowModelBindingException(Boolean sourceContent, Boolean modelContent, Type sourceType, Type modelType) +639
       Umbraco.Web.Mvc.RenderModelBinder.BindModel(Object source, Type modelType, CultureInfo culture) +420
       Umbraco.Web.Mvc.UmbracoViewPage`1.SetViewData(ViewDataDictionary viewData) +180
       System.Web.Mvc.WebViewPage.ConfigurePage(WebPageBase parentPage) +57
       System.Web.WebPages.<>c__DisplayClass3.<RenderPageCore>b__2(TextWriter writer) +218
       System.Web.WebPages.HelperResult.WriteTo(TextWriter writer) +10
       System.Web.WebPages.WebPageBase.Write(HelperResult result) +80
       System.Web.WebPages.WebPageBase.RenderSurrounding(String partialViewName, Action`1 body) +63
       System.Web.WebPages.WebPageBase.PopContext() +237
       System.Web.WebPages.WebPageBase.ExecutePageHierarchy(WebPageContext pageContext, TextWriter writer, WebPageRenderingBase startPage) +98
       System.Web.Mvc.RazorView.RenderView(ViewContext viewContext, TextWriter writer, Object instance) +235
       System.Web.Mvc.BuildManagerCompiledView.Render(ViewContext viewContext, TextWriter writer) +107
       Umbraco.Core.Profiling.ProfilingView.Render(ViewContext viewContext, TextWriter writer) +113
       System.Web.Mvc.ViewResultBase.ExecuteResult(ControllerContext context) +290
       System.Web.Mvc.ControllerActionInvoker.InvokeActionResult(ControllerContext controllerContext, ActionResult actionResult) +13
       System.Web.Mvc.ControllerActionInvoker.InvokeActionResultFilterRecursive(IList`1 filters, Int32 filterIndex, ResultExecutingContext preContext, ControllerContext controllerContext, ActionResult actionResult) +56
       System.Web.Mvc.ControllerActionInvoker.InvokeActionResultFilterRecursive(IList`1 filters, Int32 filterIndex, ResultExecutingContext preContext, ControllerContext controllerContext, ActionResult actionResult) +420
       System.Web.Mvc.ControllerActionInvoker.InvokeActionResultWithFilters(ControllerContext controllerContext, IList`1 filters, ActionResult actionResult) +52
       System.Web.Mvc.Async.<>c__DisplayClass2b.<BeginInvokeAction>b__1c() +173
       System.Web.Mvc.Async.<>c__DisplayClass21.<BeginInvokeAction>b__1e(IAsyncResult asyncResult) +100
       System.Web.Mvc.Async.WrappedAsyncResult`1.CallEndDelegate(IAsyncResult asyncResult) +10
       System.Web.Mvc.Async.WrappedAsyncResultBase`1.End() +49
       System.Web.Mvc.Async.AsyncControllerActionInvoker.EndInvokeAction(IAsyncResult asyncResult) +27
       System.Web.Mvc.Controller.<BeginExecuteCore>b__1d(IAsyncResult asyncResult, ExecuteCoreState innerState) +13
       System.Web.Mvc.Async.WrappedAsyncVoid`1.CallEndDelegate(IAsyncResult asyncResult) +29
       System.Web.Mvc.Controller.EndExecuteCore(IAsyncResult asyncResult) +36
       System.Web.Mvc.Controller.<BeginExecute>b__15(IAsyncResult asyncResult, Controller controller) +12
       System.Web.Mvc.Async.WrappedAsyncVoid`1.CallEndDelegate(IAsyncResult asyncResult) +22
       System.Web.Mvc.Controller.EndExecute(IAsyncResult asyncResult) +26
       System.Web.Mvc.Controller.System.Web.Mvc.Async.IAsyncController.EndExecute(IAsyncResult asyncResult) +10
       System.Web.Mvc.MvcHandler.<BeginProcessRequest>b__5(IAsyncResult asyncResult, ProcessRequestState innerState) +21
       System.Web.Mvc.MvcHandler.EndProcessRequest(IAsyncResult asyncResult) +28
       System.Web.Mvc.MvcHandler.System.Web.IHttpAsyncHandler.EndProcessRequest(IAsyncResult result) +9
       System.Web.CallHandlerExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute() +9744261
       System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously) +155
    Any ideas?
    Jul 19, 2016 @ 15:29
    Alex Skrypnyk
    Hi Jon,
    What Umbraco version are you using?
    Try to change MdelBuilder Mode to DLL in web.config:
      <add key="Umbraco.ModelsBuilder.ModelsMode" value="Dll" />
    Alex
    Jul 20, 2016 @ 08:48
    Jon
    It comes up with a new error with "Dll"
    Compilation Error Description: An error occurred during the compilation of a resource required to service this request. Please review the following specific error details and modify your source code appropriately.
    Compiler Error Message: CS0234: The type or namespace name 'Frontpage' does not exist in the namespace 'Umbraco.Web.PublishedContentModels' (are you missing an assembly reference?)
    Source Error:
    Line 40:
    Line 41:
    Line 42:     public class _Page_Views_Frontpage_cshtml : Umbraco.Web.Mvc.UmbracoTemplatePage<ContentModels.Frontpage> {
    Line 43:
    Line 44: #line hidden
    Jul 20, 2016 @ 08:50
    Alex Skrypnyk
    Jon, try to rebuild models manually, go to Developers Section -> Models Builder tab and press Generate Models button.
    Alex
    Jul 20, 2016 @ 08:49
    Jon
    Umbraco version 7.4.3 assembly: 1.0.5948.18141
    Jul 20, 2016 @ 10:32
    Jon
    Brilliant! It seems like that was the trick :-)
    Thanks!
    Alex Skrypnyk
    You are welcome ! Great that we found the solution !
    Jul 20, 2016 @ 10:33
    Jon
    ...of curiosity; Why change was it necessary to change the modelBuilder?
    Jul 20, 2016 @ 12:20
    Alex Skrypnyk
    It goes like this: Dll models generate a DLL when a button is clicked... LiveDll models are generated whenever content types change, but this causes an application restart... and then there is "PureLive" which sort-of is "live" without the restart--but with some restrictions, such as models being visible only in views.
    So PureLive makes some problems sometimes, but it's default state.
    Alex
  • Chris Clancy 65 posts 134 karma points
    Nov 30, 2016 @ 10:30
    Chris Clancy
    This is a great explanation Alex. I had a site setup with PureLive but in Visual Studio I was seeing messages complaining about missing references, although the site was working as expected.
    I have changed ModelsBuilder to Dll and rebuilt the models in the back office and everything runs ok, with no more error messages in VS. I can't say I've noticed a huge improvement in speed but there should be no more of the 'your app may be unstable' messages appearing.
    Nov 30, 2016 @ 23:02
    Alex Skrypnyk
    Hi Chris,
    You will not have significant performance changes when classes are in dll or internal memory. But definitely locally it's better to work in Dll mode, because of an issue with visual studio.
    Another possible way to work with strongly typed classes - AppData Models, read more about this setting - https://github.com/zpqrtbnk/Zbu.ModelsBuilder/wiki/Builder-Modes
    In two words - you have classes generated under AppData folder, just include them to project and you have visual studio support. The nice feature is that you do not have to rebuild site when change some docType.
    I hope it will help you/
    Alex
    Dec 01, 2016 @ 11:32
    Chris Clancy
    Thanks for the link Alex. Very useful.
