  • glob 72 posts 172 karma points
    Jul 20, 2016 @ 04:57
    glob
    Not able to render inline macro in RTE via SurfaceController
    I am using umbraco 7+ with mvc application.
    If I load a node directly through its URL, the macro inside RTE renders well.
    But, when I load the same node, on a button click, which calls a controller and returns the same node in partial view - the macro fails to render with this error:
    'Cannot render a macro when there is no current PublishedContentRequest. '
    Is this similar to http://issues.umbraco.org/issue/U4-6206 - if so, is there a workaround to this issue?
    With regards,
