  • David McGawn 37 posts 150 karma points
    Aug 08, 2016 @ 09:48
    David McGawn
    Monday Morning Brain Freeze - Help :-)
    I am trying to use the name of the image file for the alt tag in the Media editor section, how will i go about this and also would aslo like it to drop the .png or .jpg etc.. also
    @if (Model.value != null){
    var url = Model.value.image;
    var urlName = "";
    if(Model.editor.config != null && Model.editor.config.size != null){
        url += "?width=" + Model.editor.config.size.width;
        url += "&height=" + Model.editor.config.size.height;
        if(Model.value.focalPoint != null){
            url += "&center=" + Model.value.focalPoint.top +"," + Model.value.focalPoint.left;
            url += "&mode=crop";
    <img src="@url" class="img-responsive2" alt="">}
  • Alex Skrypnyk 6182 posts 24283 karma points MVP 8x admin c-trib
    Aug 08, 2016 @ 10:42
    Alex Skrypnyk
    Hi David,
    Agree with you that Monday is hard day :)
    You can try Path.GetFileNameWithoutExtension method:
    string fileName = @"C:\mydir\myfile.ext";
    string result = System.IO.Path.GetFileNameWithoutExtension(fileName);
    Alex
    Aug 08, 2016 @ 10:45
    David McGawn
    Yeah that is brilliant just what i need, need to figure out how to get the file name to string first into the alt tag :-(
    Aug 08, 2016 @ 10:48
    Alex Skrypnyk
    url.ToString()
    Aug 08, 2016 @ 10:53
    David McGawn
    Yeah thats what i have done so far but that gives me the full media url :-(
    Alex Skrypnyk
    Another one:
    string stringUrl = url;
    Aug 08, 2016 @ 10:54
    Alex Skrypnyk
    string fileName = url.ToString();
    Aug 08, 2016 @ 10:56
    David McGawn
    Got it i had used the first varible in the alt tag, theses mondays are a killer :-( i had used @fileName #sillyme
    Aug 08, 2016 @ 10:57
    Alex Skrypnyk
    )) So ) Is it fixed?
    Aug 08, 2016 @ 11:01
    David McGawn
    Yip all working now, your a star :-)
    var urlName = url.ToString();
    string result = System.IO.Path.GetFileNameWithoutExtension(urlName);
    if (Model.editor.config != null && Model.editor.config.size != null)
    if (Model.value.focalPoint != null)
      url += "&center=" + Model.value.focalPoint.top + "," + Model.value.focalPoint.left;
    <img src="@url" class="img-responsive2" alt="@result">
    // if (Model.value.caption != null)
    //    <p class="caption">@Model.value.caption</p>
    Aug 08, 2016 @ 11:04
    Alex Skrypnyk
    Cool, glad to help you ) Can you mark topic solved?
    Write if something else.
    Alex
