  • Sameer 6 posts 88 karma points
    Aug 23, 2016 @ 07:26
    Sameer
    Query where clause is not producing desired results
    Hi there, I am working in a partial view and I need to get video lectures in a partial view. Following is query that is working fine
    @using YouTube
    @using YouTube.Models
        var homePage = CurrentPage.AncestorsOrSelf(1).First();
        var lectureVideos = homePage.Descendants("videoLecture").Where("Visible").OrderBy("publishDate desc, createDate desc");
    But I need to filter the videos based on their description property named as "lectureDescription", a rich text editor. I want to exclude those videos having no description. I have run the following query but it's not working and its giving no result at all.
    @using YouTube
        var lectureVideos = homePage.Descendants("videoLecture").Where("Visible").Where("lectureDescription != @0 && lectureDescription != @1",null,String.Empty).OrderBy("publishDate desc, createDate desc");
    Can someone point out and guide me into right direction, I will be thankful.
    Aug 24, 2016 @ 06:01
    Sameer
    Anyone? Kindly give me any suggestion.
  • David Brendel 792 posts 2970 karma points MVP 3x c-trib
    Aug 24, 2016 @ 06:46
    David Brendel
    Hi Sameer,
    I'm not working with the dynamic syntax but maybe you can cross check what happens when you use the strongly typed one.
    Something like
    homePage.Descendants("videoLecture").Where(x => x.IsVisible()).Where(x => !String.IsNullOrEmpty(x.GetPropertyValue<string>("lectureDescription")));
    Maybe that helps to figure out what the problem is.
    Regards David
