  • Volodymyr 8 posts 88 karma points
    Sep 20, 2016 @ 09:11
    Volodymyr
    Problem with umbraco v 4.7.1 when try to enter into content via https
    Hi all, I have problem with umbraco v 4.7.1: when I try to enter into the content with macro (googlemap script is inside) via https I receive next error
    "Server Error in '/' Application.
    Request timed out.
    Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code. Exception Details: System.Web.HttpException: Request timed out. Source Error: An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of the exception can be identified using the exception stack trace below. Stack Trace: [HttpException (0x80004005): Request timed out.]",
    when I use http all is OK. Maybe some of you know solution or have an idea how i can solve it?
  • Alex Skrypnyk 6182 posts 24283 karma points MVP 8x admin c-trib
    Sep 20, 2016 @ 16:54
    Alex Skrypnyk
    Hi Volodymyr,
    Can you read this topic - https://our.umbraco.org/forum/getting-started/installing-umbraco/9723-Macro-rendering-in-backend-over-HTTPS-SSL ?
    Did you set "enablessl" to true?
    Alex
    Sep 21, 2016 @ 09:14
    Volodymyr
    Hi Alex, thank you for thread, i solved a problem
