Below is the screenshot of global site settings under settings where we select the maintenance mode checkbox and display content for publishing maintenance page on our website.
After publishing this settings we also publish the entire site,but after some time it automatically gets deselected.
After selecting maintenance mode it gets reverted after some time.
We are selecting maintenance mode checkbox option as checked from umbraco and after an hour the checkbox are getting unchecked.
Is this issue is regarding cache or we need to change some settings?
Please let us know ?
Hi Manvendra,
What do you mean maintenance mode?
How did you set this setting?
Alex
Hi Alex,
Could you please suggest on this.
Thanks, Manvendra
Hi Manvendra,
This checkbox is doing some custom code, we can't know what exactly it is. It's not Umbraco out of the box functionality.
Can you look at source code of your site?
And try to find using of this property value.
Oleksandr Skrypnyk
Hi Manvendra,
Did you solve the problem?
Can we help you?
Alex
Hi Alex,
No, still the issue is not resolved.
Currently we have hosted our application on Azure Cloud service and there is two instance created for the application.
Does the changes are getting reverted due to the two instance ?
Because when the changes are reverted after some time and again we perform the changes for maintenance mode it works properly.
Thanks, Manvendra
Hi Manvendra,
What about database?
Is it the same for both instances?
Alex
Hi Alex,
Yes the database is same.
Thanks, Manvendra
Hi Manvendra,
We need to look at source code, can you try to find what your site do with this checkbox?
Alex
