  • Arunabha Das 38 posts 151 karma points
    Oct 24, 2016 @ 11:36
    Arunabha Das
    ezSearch is not searching Chinese character
    ezSearch is not searching Chinese character. Search is working with single character but not with more than single character. enter image description here
    not with
    Please let me know any solution on that.
    Oct 24, 2016 @ 14:00
    Ismail Mayat
    Arunabha,
    By default the indexer is set to standard analyser in the Examine config file which is what ezsearch uses. You need a chinese analyser. You will need to lucene.net contrib you can get it via nuget and install then in the examine config files set the analyser to chinese then rebuild the index.
    See this https://our.umbraco.org/projects/website-utilities/full-text-search/bugs/80462-full-text-search-doesnot-support-to-search-chinese-texts
    Regards
    Ismail
    Nov 03, 2016 @ 12:22
    Arunabha Das
    Hi Ismail,
    I have copied the dll ( Lucene.Net.Contrib.Analyzers)and updated the ExamineSettings.config file. But still I am not able get results.
