  • Gert 81 posts 288 karma points
    Nov 07, 2016 @ 10:05
    Gert
    Problem fetching image in view in Umbraco 7.5
    This code worked perfectly fine in Umbraco 7.3.
    var image = Umbraco.TypedMedia( ( int )CurrentPage.BannerBackgroundImage.Id );
    BannerBackgroundImage is of data type Media Picker.
    In a clean Umbraco 7.5.4 install I get the following Exception (RuntimeBinderException).
    'Umbraco.Web.Models.DynamicPublishedContentList' does not contain a definition for 'Id'
    Umbraco.ModelsBuilder.Enable is set to false in the web.config.
    How should I solve this?
    Thanks! Gert.
  • carlu 42 posts 131 karma points
    Nov 08, 2016 @ 08:43
    carlu
    Hi Gert,please try it
    @if (CurrentPage.HasValue("BannerBackgroundImage")) {
                          @{var dynamicMediaItem = Umbraco.Media(CurrentPage.BannerBackgroundImage);
                         <img src="@dynamicMediaItem.umbracoFile" alt="@dynamicMediaItem.Name" style="width:100%; " />
    Nov 08, 2016 @ 10:22
    Gert
    Hi Carlu,
    This didn't help, but the following did
     IPublishedContent image = Umbraco.TypedMedia( CurrentPage.BannerBackgroundImage.First().Id );
    So it's a mystery to me why the Media Picker suddenly returns a collection in Umbraco 7.5? I also had to explicitely define the type IPublishedContent because when I used the var keyword, then the type was not correctly inferred and the call:
    imageUrl = image.GetCropUrl( 800, 600 );
    did not work. Image then turnes out to be of type dynamic and the call GetCropUrl() throws an exception: 'Umbraco.Web.Models.PublishedContentWithKeyBase' does not contain a definition for 'GetCropUrl'
    What is also strange is that the call image.GetPropertyValue( "umbracoWidth" ); returns a string now instead of an integer. Any idea why this is changed in Umbraco 7.5?
    Regards, Gert.
    Nov 08, 2016 @ 10:51
    Gert
    I found a solution for the media picker returning a collection. When I go the the Media Picker data type and I check the option, "Pick multiple items", save it, uncheck it and save it again then the media picker property won't return a collection but instead a single (dynamic) Umbraco.Web.Models.PublishedContentWithKeyBase which should be casted to IPublisheContent.
    Cheers, Gert.
