var listValues = "1234,1235,1236";
var resultsList = listValues.Split(',').Select(int.Parse);
var collection = Umbraco.AssignedContentItem.Children.Where(x => x.IsVisible()).Where(x => x.GetPropertyValue<int[]>("subscriptionOptions").Intersect(resultsList).Any());
foreach (var id in collection)
<p>@id</p>
Look please at my code example, I used totally strongly typed variables and linq Intersect method for finding common items in 2 arrays.
Description: An unhandled exception occurred during the execution of
the current web request. Please review the stack trace for more
information about the error and where it originated in the code.
Exception Details: System.ArgumentNullException: Value cannot be null.
Parameter name: first
Source Error:
So I substituted
Umbraco.AssignedContentItem for CurrentPage and I get
Description: An error occurred during the compilation of a resource
required to service this request. Please review the following specific
error details and modify your source code appropriately.
Compiler Error Message: CS1977: Cannot use a lambda expression as an
argument to a dynamically dispatched operation without first casting
it to a delegate or expression tree type
Source Error:
Line 112:var resultsList = listValues.Split(',').Select(int.Parse);
Line 113: Line 114:var collection = CurrentPage.Children.Where(x =>
x.GetPropertyValue
Exception Details: System.NullReferenceException: Object reference not
set to an instance of an object.
Source Error:
Thanks Alex, your last post put me on the right track.
I added in the DocumentTypeAlias (as there are other unlrelated children without the subsriptionOptions field) and used the syntax of your previous post plus the intersect of the last post and came up with this.
Help with a dynamic query in where clause UMBRACO 7 Razor
Having trouble creating a dynamic query within umbraco. Razor
Thought I had it but I think I am missing something fundamental.
Any help would be appreciated or a different approach.
Basically I have a set of products that may or may not have selected items in a multipicker.
Just accessing one item would be simple enough.
var collection = CurrentPage.Children("product").Where("visible").Where("subscriptionOptions.Contains(@0)", "1234")
But I would like to dynamically generate that last where. and came up with this.
The final result looks exactly as I want it when i simple render
@dynamicQuery
to the page it looks for example like this.But when I call.
I get
Exception Details: Umbraco.Core.Dynamics.ParseException: Expression of type 'Boolean' expected
Any ideas...
btw I am a long time user but can't log in on my usual username as the password reset on our.umbraco seem borked.
Kind Regards
Rob
Hi Rob,
Lets rewrite this code to strongly typed?
What do you think?
Just provide code of all file and we will do it together, don't like to use dynamics sorry.
Thank,
Alex
Well this is this the bit I am working on.
What it is supposed to do it look at a node called product then look in the subscriptionOptions of that node which is a multipicker
and see if the listValues passed from the previous page are there listValues is passed initiall as say...
1234,1235,1236,
I strip of the last , leaving it as
"1234,1235,1236"
Which is then turned into a list or rather in this case var called resultsList
Hi again Rob,
Can you test it and give me feedback?
Alex
Hi not sure here...
I pasted it in the bit and it gave me.
So I substituted
Try this line:
Sorry for the late response. Hell of a commute.
I am getting
Ok I changed it to...
And made sure all subscribeProduct pages have at least one value in subscriptionOptions
It returns all 7 products.. regardless of the values in subscribeOptions
Ok I have narrowed down what's happening and still need a little help.
the subscriptionProduct must have ALL listItems present within the multipicker subscriptionOptions
So a product1 would have say 1111,2222,3333,4444,5555,6666,7777 in its subscription options
product2 perhaps 1111,2222,3333,4444,5555
and product3 1111,3333,4444,5555
if listItems is say 1111,2222,3333,4444
only product 1 and 2 would be returned to the collection.
your help so far seems to be acting like or rather than and
I hope I have explained it better this time :)
Thankyou so much for you help so far.
Rob, great description of task !!!
I hope I wil help you to solve the issue.
Alex
Hi Rob,
Now it's more clear, last code snipped found even one common id.
This code will find children with all resultsList ids:
Alex
Which appears to work. I will put some more tests intomorrow as it's getting late but it looks perfect.
Thanks so much for your help with this and the time you have taken to assist.
Kind Regards Rob
