  • Richard Green 6 posts 88 karma points
    Nov 25, 2016 @ 17:50
    Richard Green
    Surface Controller Not Invoking on Submit
    Hi all.
    Sometime ago, I created a surface controller, model and partial for a contact form. Nothing complicated, just a simple form that uses SendGrid to deliver an email on submission.
    Somehow, I've broken the hook between the page and the surface controller such that hitting Submit triggers a HTTP POST but then nothing actually happens and I can't figure out why.
    Can anyone offer any suggestions as to what stupid thing I have done? FWIW, I'm running Umbraco version 7.4.3.
    Surface Controller
    using System.Web.Mvc;
    using ArcibleWebsite.Models;
    using System.Net.Mail;
    using SendGrid.Helpers.Mail;
    using Newtonsoft.Json;
    namespace ArcibleWebsite.Controllers
    public class ContactSurfaceController :                                   Umbraco.Web.Mvc.SurfaceController
        [HttpPost]
        public ActionResult CreateContactMessage(ContactViewModel contactFormData)
            if (!ModelState.IsValid)
                return CurrentUmbracoPage();
            ViewBag.Contact = contactFormData;
            // Global variables for building the messages
                SENDGRID STUFF HAPPENS HERE
            // return CurrentUmbracoPage();
            return RedirectToCurrentUmbracoPage;
    Model
    using System.ComponentModel.DataAnnotations;
    namespace ArcibleWebsite.Models
        public class ContactViewModel
        [Required]
        [StringLength(50, MinimumLength = 3)]
        [Display(Name = "First Name")]
        public string FirstName { get; set; }
        [Required]
        [Display(Name = "Last Name")]
        public string LastName { get; set; }
        [Required]
        [EmailAddress]
        [DataType(DataType.EmailAddress)]
        [Display(Name = "Email Address")]
        public string EmailAddress { get; set; }
        [StringLength(20, MinimumLength = 10)]
        [Display(Name = "Contact Number")]
        public string ContactNumber { get; set; }
        [Required]
        [StringLength(2500, MinimumLength = 10)]
        [DataType(DataType.MultilineText)]
        public string Message { get; set; }
    Partial
    @model ArcibleWebsite.Models.ContactViewModel
    @using (Html.BeginUmbracoForm<ArcibleWebsite.Controllers.ContactSurfaceController>("CreateContactMessage"))
    if (!ViewData.ModelState.IsValid)
        <div class="row">
            <div class="col-xs-12 col-sm-6 col-md-8">
                @Html.ValidationSummary(true, "Sorry, but there is a problem with the data you've entered. Please check the data you entered and try again.")
            FORM STUFF HAPPENS HERE
            <input type="submit" class="btn btn-pink" value="Submit your Question" />
        </form>
  • Aditya 24 posts 128 karma points
    Nov 26, 2016 @ 08:06
    Aditya
    Hmm, looks OK at first glance. Have you tried using Visual Studio's debugger to step through your code? That might help show where it loses the call.
    Nov 26, 2016 @ 11:45
    Nik
    My first thought, is check the rendered HTML and network traffic. It might be doing a GET instead of a POST hence never getting to your controller.
    Generally I find it safer to specify the form is a post.
    Also, if the controller code isn't complete, make sure you don't have a GET and a POST called the same thing (on the same controller), I find in Umbraco they conflict and it causes issues.
    Nik
  • Dennis Adolfi 1082 posts 6450 karma points MVP 6x c-trib
    Nov 26, 2016 @ 12:57
    Dennis Adolfi
    Hi Richard.
    Looking at your controller, it looks like it's missing the inheritance for SurfaceController. So at the moment it's just a regular class and not routed as a controller, which is why your code compiles fine but the forms cannot post to your actionresult.
    I'm guessing since it used to work it might be something you've accidentally removed somehow.
    Change it to:
    public class ContactSurfaceController : SurfaceController
    Hope this solves the problem.
    Have a great weekend!
    Nov 26, 2016 @ 16:17
    Richard Green
    Hi Dennis.
    The reference is there, it's just got a little mangled by the code posted. Here's just that singular line:
    Is the fact that I'm having to reference SurfaceController using it's full name and the lack of a using statement for Umbraco.Web.Mvc a problem?
    Nov 26, 2016 @ 17:46
    Marc Goodson
    Hi Richard
    I just cut and paste what you have into the fanoe starter kit, and it all sort of works...
    you shouldn't need the closing
    </form>
    tag though inside your @using (Html.BeginUmbracoForm bit (that will be taken care of by the BeginUmbracoForm itself...
    having that on it's own breaks parsing of the partial razor file...
    is that the issue ?
    If that's not the issue then it could be the way in which you are presenting the form fields, which we can't see:
    I just did:
    @Html.EditorFor(f=>f.FirstName)
    <br  />
    @Html.EditorFor(f=>f.ContactNumber)
    <br  />
    @Html.EditorFor(f=>f.EmailAddress)
    <br />
    @Html.EditorFor(f=>f.LastName)
    <br />
    @Html.EditorFor(f=>f.Message)
    so if you have something different to that ? maybe it's not binding to the properties of the model... ?
    Finally it does have some strict validation on the model, eg more than 10 characters for some fields etc, so make sure your validation is showing, I turned on the validation summary
    @Html.ValidationSummary(false, "Sorry, ....
    to see the messages, but you probably have Html.ValidationFor within your form...
    Anyway hope that helps from a sanity perspective.
    regards
    Marc
  • Dan Diplo 1554 posts 6205 karma points MVP 6x c-trib
    Nov 26, 2016 @ 17:59
    Dan Diplo
    It looks like you have an extra closing </form> tag in there. When using Html.BeginUmbracoForm you shouldn't add any other form tags, otherwise the form won't submit. So check that.
  • Piotr Bach 18 posts 138 karma points c-trib
    Nov 26, 2016 @ 18:09
    Piotr Bach
    Hi.
    Check the form-generated output html:
    <form action="/Contact" class="email-form" enctype="multipart/form-data" method="post" role="form" novalidate="novalidate"><input name="__RequestVerificationToken" type="hidden" value="HJP27AVfpIJgJf3p9NHsArq8k1Jts01vzwEyr3f5dKizkA42zRBGlAUqqv3by_pUlr1vUDq5cS4jWe3Sn_yBLbA1e_VVNuawYX9BdIt1DAA1">    <h2>Send a quick message</h2>
    <div class="form-group">
        <label for="Email">Your Email *</label>
        <input class="form-control" data-val="true" data-val-email="The Email field is not a valid e-mail address." data-val-required="The Email field is required." id="Email" name="Email" type="text" value="">
        <span class="field-validation-valid" data-valmsg-for="Email" data-valmsg-replace="true"></span>
        <label for="Message">Your Message *</label>
        <textarea class="form-control" cols="20" data-val="true" data-val-required="The Message field is required." id="Message" name="Message" rows="2"></textarea>
        <span class="field-validation-valid" data-valmsg-for="Message" data-valmsg-replace="true"></span>
    <div class="overflow-hidden">
        <input class="btn btn-success pull-right" type="submit" value="Send">
    Then check if you're really hitting controller method with post (console debugger in browser + vs debug)
    This code is working for me:
    @{ Html.RenderPartial("_Contact", new ContactFormViewModel()); }
    _Contact.cshtml
    @model Site.Web.ViewModel.ContactFormViewModel
    @using Site.Web.Controllers;
    @using System.Web.Mvc.Html
    @using ClientDependency.Core.Mvc
    @using Umbraco.Web
    @using Umbraco.Web.Models
    @using Umbraco.Web.Controllers
        Html.EnableClientValidation();
        Html.EnableUnobtrusiveJavaScript();
        Html.RequiresJs("/umbraco_client/ui/jquery.js");
        Html.RequiresJs("/umbraco_client/Application/JQuery/jquery.validate.min.js");
        Html.RequiresJs("/umbraco_client/Application/JQuery/jquery.validate.unobtrusive.min.js");
    @Html.RenderJsHere()
            @if (TempData["Status"] == null) {
    using (Html.BeginUmbracoForm<ContactController>("Submit", new object { }, new { @class = "email-form", @role = "form" }))
        @Html.AntiForgeryToken()
            @Html.LabelFor(m => m.Email, "Your Email *")
            @Html.TextBoxFor(m => m.Email, new { @class = "form-control" })
            @Html.ValidationMessageFor(m => m.Email)
            @Html.LabelFor(m => m.Message, "Your Message *")
            @Html.TextAreaFor(m => m.Message, new { @class = "form-control" })
            @Html.ValidationMessageFor(m => m.Message)
            <input class="btn btn-success pull-right" type="submit" value="Send" />
    @if (TempData["Status"] != null)
        <div class="alert alert-success" role="alert">@TempData["Status"] <a href="/Home" class="alert-link">go to home page</a> </div>
    ContactController.cs
     public class ContactController : SurfaceController
            [HttpPost]
            [ValidateAntiForgeryToken]
            public ActionResult Submit(ContactFormViewModel model)
                //some logic
                TempData["Status"] = "Message was send";
    Good luck
    Nov 26, 2016 @ 18:37
    Dennis Adolfi
    Ah i see! Thought I found the obvious answer! :)
    Maybe, not sure though. You could try to reference Umbraco.Web.Mvc with the using statement and see if that works, but I'm skeptical..
    As Nik mentioned, could you paste in the rendered HTML and maybe we can see what actually gets rendered.
    Dec 03, 2016 @ 00:30
    Richard Green
    Thanks everyone for the replies. I updated the code, adding the reference to Umbraco.Web.Mvc so that SurfaceController didn't need to be fully qualified and I updated the form tags in the partial.
    Everything is now working so I'm not exactly sure which of those two actually resolved it but I suspect it was the form tags.
    Many thanks to all.
