  • Aaron Lett 21 posts 72 karma points
    Dec 06, 2016 @ 23:03
    Aaron Lett
    GetCropUrl inside of foreach loop for Carousel
    Hey guys,
    So I'm trying to dynamically insert a crop I've defined ("Banner") into a loop and call the image URL that I used as a Main Image ("marqueeImage"). I'm wicked close, but I can't clear the last hurdle to get the actual cropped image to show.
    My code:
        //Fetch the blogposts from a certain node id
        var blogPosts = Umbraco.Content(1370);
        foreach(var blogPost in blogPosts.Children.Take(4)){
        <div class="row">
            <div class="col-sm-12">
                <article class="linkbox cat-sports">
                    <a href="@blogPost.Url">
                        <img src="@blogPost.GetCropUrl("marqueeImage", "Banner")" width="1170" height="480" alt="Responsive image" class="img-responsive" />
                        <div class="overlay">
                            <h2>@blogPost.Name</h2>
                            <p>@blogPost.theatre - Reviewed on: @blogPost.reviewedPerformanceDate.ToLongDateString()</p>
                    </a>
                    <a href="#" class="theme">
                        Review
                    </a>
                </article>
    Any pointers to the right direction/syntax would be a big help! I tried to apply the markup from https://our.umbraco.org/documentation/getting-started/backoffice/property-editors/built-in-property-editors/image-cropper to no avail....
  • Dennis Adolfi 1082 posts 6450 karma points MVP 6x c-trib
    Dec 07, 2016 @ 13:56
    Dennis Adolfi
    Hi Aaron.
    From what I can see, you´ve done everything correctly.
    Can you double/triple check that your Image Croppper property alias is exaclty marqueeImage and that the crop is Banner?
    And then make sure you have fetched the correct BlogPost page (1370) and that all children have a images saved and published. (I´ve noticed you use a Take(), maybe you are debugging the wrong children?)
    Other than that, it looks correct!
    Best of luck!
  • Matthew Kirschner 323 posts 611 karma points
    Dec 07, 2016 @ 14:20
    Matthew Kirschner
    Hi, Aaron.
    That should work if you're using a media cropper. In the off chance that you're using a media picker instead, you would need to crop your image like so:
    var mediaObject = Umbraco.TypedMedia(blogPost.GetPropertyValue<int>("marqueeImage"));
    Url.GetCropUrl(mediaObject, propertyAlias: "umbracoFile", height: 480, width: 1170);
    Dec 07, 2016 @ 16:11
    Aaron Lett
    Okay, I'll expound and affirm.
    Dennis: The Property Alias is marqueeImage and the crop is Banner.
    Matthew: And you are also correct; marqueeImage IS a single-item media picker (I want to chose from the existing Media Library - not upload the same image multiple times).
    So I tried your addition (in the syntax per the Image Cropper Documentation) as thus:
        <div class="row">
                            <img src='@Url.GetCropUrl(mediaObject, propertyAlias: "umbracoFile", height: 480, width: 1170)' width="1170" height="480" alt="Responsive image" class="img-responsive" />
                        </a>
                            Review
                        </a>
                    </article>
    To again no avail (Bow it throws a 'Compilation Error'). It still feels oh-so-close....
    Dec 07, 2016 @ 16:21
    Matthew Kirschner
    Can you give us a more verbose error besides "Compilation Error"?
    You can do this by getting the error from the Umbraco log or running your solution in debug mode.
    Dec 07, 2016 @ 16:48
    Aaron Lett
    The shortened response is:
    Compiler Error Message: CS1739: The best overload for 'GetCropUrl' does not have a parameter named 'propertyAlias'
    On the line:
    Dec 07, 2016 @ 17:04
    Matthew Kirschner
    Which version of Umbraco are you using?
    Dec 07, 2016 @ 17:21
    Aaron Lett
    Dec 07, 2016 @ 18:33
    Matthew Kirschner
    Hmmm, you should definitely have the Url extension methods then.
    Regardless, try this on your TypedMedia object:
    @mediaObject.GetCropUrl(1170, 480);
    Dec 07, 2016 @ 17:52
    Dennis Adolfi
    Ok, so try:
    @mediaObject.GetCropUrl("Banner");
    Dec 07, 2016 @ 19:10
    Aaron Lett
    Still much nope....
    I changed TypedMedia to Media in the
    declaration... The page displays, but in the debug console I am now getting:
    500 (Internal Server Error) for all the images....
    So code now is:
        <div class="row">
                    var mediaObject = Umbraco.Media(blogPost.GetPropertyValue<int>("marqueeImage"));
                            <img src='@mediaObject.GetCropUrl("Banner")' width="1170" height="480" alt="Responsive image" class="img-responsive" />
                        </a>
                    <a href="#" class="theme">Review</a>
                    </article>
    Dec 07, 2016 @ 19:40
    Matthew Kirschner
    I don't think using Media or TypedMedia should matter here, though I try to use Typed objects as much as possible.
    Did you try my suggestion above?
    If this works, it could imply that the crop you're trying use, "Banner", is the problem.
    Dec 07, 2016 @ 20:20
    Aaron Lett
    <img src='@mediaObject.GetCropUrl(1170, 480)' width="1170" height="480" alt="Responsive image" class="img-responsive" />
    Still not working...
    Dec 07, 2016 @ 20:33
    Matthew Kirschner
    What's the error this time?
    Dec 07, 2016 @ 20:35
    Aaron Lett
    Okay, update:
    in the DOM, the image IS being loaded:
    http://thecolumnonline.stuckomonkeyproductions.com/media/1113/image.jpeg?mode=crop&width=1170&height=480&rnd=131255086590000000
    However is displays nothing.
    Going to just the image pre-crop it exists ( http://thecolumnonline.stuckomonkeyproductions.com/media/1113/image.jpeg ).
    Is there something amiss in the stock query?
