We are facing an issue with the umbraco site which was migrated from version 6.2.1 to version 7.4.3.
There are pages which are created as Tabbed pages .The links of these pages are not changed as per the version required for Umbraco7.4.3.
Referring to the property "Link to document" available in the properties type of the content pages.
Is there a way to rebuild these links of the content pages so that they get created as required for the current Umbraco version.
Thanks.
Hi Sreeraghavendra,
Have you tried to republish the whole site. What you could do is right click on the "CONTENT" and then choose Republish entire site, what this does is that it regenerates the XML file which contains the published content.
The XML file is located in /App_Data/umbraco.xml.
Hope this helps,
/Dennis
Upload image
Issue with the property "Link to document" built in property
Thanks.
Hi Sreeraghavendra,
Hope this helps,
/Dennis
