  • Gísli Freyr Svavarsson 43 posts 126 karma points
    Jan 18, 2017 @ 10:26
    Rendering partial view in macro
    Hi kids.
    Is it possible to render a partial view in a macro? When I try
    @Html.Partial("_PARTIAL-ALIAS")
    I get this error "Cannot bind source type Umbraco.Web.Models.PartialViewMacroModel to model type Umbraco.Web.Models.RenderModel."
    @Umbraco.Field("_search-form")
    This doesn't render the content.
  • Dennis Adolfi 1082 posts 6450 karma points MVP 7x c-trib
    Jan 18, 2017 @ 10:55
    Dennis Adolfi
    Hi Gísli.
    The way you've written in you first code is correct, by writing Html.Partial(".."). The problem however is that if you are inside a macro partial view (which im suspecting), then that view is inheriting from PartialViewMacroModel and the partial view that you trying to include with a partial has a model of type RenderModel, usually because partial views created from the backoffice have this as the first line of code:
    How does your partial look? Can you paste in your code from the search-form partial? Do you need that partial to inherit from UmbracoTemplatePage? If not then remove that line. If yes, we can have a look at your code and see how to fix this.
    Take care!
    Jan 18, 2017 @ 11:28
    Thank you Dennis. I removed the @inherits Umbraco.Web.Mvc.UmbracoTemplatePage and that did the trick.
    mvh
    Jan 18, 2017 @ 11:36
    Dennis Adolfi
    Awesome! Happy to be able to help! :)
    Take care and have a great day!
  • Wilson Almonte 5 posts 75 karma points
    Mar 19, 2020 @ 20:09
    Wilson Almonte
    Also you can use Html.RenderPartial, and with this you don't need to remove @inherits Umbraco.Web.Mvc.UmbracoTemplatePage
