  • Łukasz Koruba 30 posts 151 karma points
    Jan 26, 2017 @ 14:20
    Łukasz Koruba
    Macro parameter Json to model
    I've got this piece of code
        var multiUrlPicker = Model.MacroParameters["linkPicker"];
        <p>@multiUrlPicker</p>
    The ouput of that is enter image description here
    How can I get json to a model? Is there something in umbraco or need to write some custom code to deserialize it?
    Jan 26, 2017 @ 14:38
    Łukasz Koruba
    So i've got this code and works correctly but is there a better way of doing it?
        var pickerParameter = Model.MacroParameters["linkPicker"];
        var multiUrls = new MultiUrls(pickerParameter.ToString());
        Link firstUrl = null;
        if (multiUrls.Any())
            firstUrl = multiUrls.First();
        if (firstUrl != null)
            <a href="@firstUrl.Url">@firstUrl.Name</a>
    Jan 26, 2017 @ 14:50
    Alex Skrypnyk
    Try to use this code:
    var data = JsonConvert.DeserializeObject(value.ToString());
    public class LinkPickerModel
        public int Id { get; set; }
        public string Name { get; set; }
        public string Url { get; set; }
        public string Target { get; set; }
        public string Hashtarget { get; set; }
    Hope it will help you.
    Alex
    Jan 26, 2017 @ 14:51
    Alex Skrypnyk
    Are you using "Multi Url Picker" or "Link Picker"?
    Jan 26, 2017 @ 14:52
    Łukasz Koruba
    It's Multi Url Picker.
    Jan 26, 2017 @ 15:24
    Alex Skrypnyk
    You can simplify these lines:
    To:
        var firstUrl = multiUrls.FirstOrDefault();
    Alex
    Jan 27, 2017 @ 08:54
    Łukasz Koruba
    Yeah, I know. But I'm wondering if there is a better way of casting macro parameter to Multi Url Picker model.
