I'm new to umbraco and want to achieve the following:
- I want to be able to create html+js-only widgets. I order for the JS to work it has to be loaded at the bottom of the page after some pre-requisite scripts (jQuery, React, Adal.js etc).
However, the HTML helper in the partial is not being triggered (the one in the masterpage IS being hit). I am wondering if I'm doing something fundamentally wrong or just doing something slightly wrong.
NB: I've noticed that when in the backoffice the method RequireScript IS called, but not EmitRequiredScripts. This is logical because EmitRequiredScripts is in the front-end masterpage. However, RequireScript is not being called in the front-end. It seems to be stripped out somehow. Similarly when I add
Partial View Macro - output script tags
I'm new to umbraco and want to achieve the following: - I want to be able to create html+js-only widgets. I order for the JS to work it has to be loaded at the bottom of the page after some pre-requisite scripts (jQuery, React, Adal.js etc).
I have followed this post: http://stackoverflow.com/questions/5355427/populate-a-razor-section-from-a-partial?rq=1 in order to inject script tags from a partial view into the bottom of a masterpage.
Here is the Partial view macro
Master.cshtml
This is the HTML helper from the stckexchange post people have used successfully:
Please let me know if this is a good way to go, what I'm doing wrong or if there are superior ways to solve this problem.
Kind Regards, Jurgen
