  • Dibs 202 posts 991 karma points
    Mar 04, 2017 @ 23:54
    Dibs
    handle malicious input with Razor in template
    HI Umbraco Team
    I have set up a simple search feature via the following link: http://www.codeshare.co.uk/blog/simple-umbraco-search-example/ . I would like to handle malicious input from the user, currently if i input a <script> tag i get error about partial view not able to be rendered and log entry.
    System.Web.HttpRequestValidationException (0x80004005): A potentially dangerous Request.QueryString value was detected from the client (keywords="**")
    How can i handle this with Razor ? Debugging catches the exception in code at
    string searchTerm = Request.QueryString["keywords"];
    Thanks Dibs
  • Dennis Adolfi 1082 posts 6450 karma points MVP 6x c-trib
    Mar 06, 2017 @ 07:31
    Dennis Adolfi
    Hi Dibs.
    Maybe you could use Regex? Not on the querystring after post but instead on the form input, preventing the user from posting malicious input. See example (This example only allows letters and numbers):
    <input type="text" placeholder="Search..." name="query" pattern="^[a-zA-Z0-9]+$">
    Live example: https://jsfiddle.net/411pk92u/
    Regex used: http://regexlib.com/REDetails.aspx?regexp_id=1014
    Best of luck!
  • Stefano 61 posts 313 karma points c-trib
    Mar 06, 2017 @ 09:21
    Stefano
    101
    That seems like a good idea! Maybe the regex could be more permissive!
    The alternative would be to allow for "potentially dangerous" request string and then handle them correctly.
    Look here https://msdn.microsoft.com/en-us/library/hh882339(v=vs.110).aspx#Anchor_0 under , skip the first part about ASP.NET Web Forms.
    Mar 07, 2017 @ 16:45
    Dibs
    Thanks for your input guys,
    I'll give both a try, maybe go with Microsoft link
    Dibs
