  • Magnus Szatkowski 28 posts 149 karma points
    Mar 09, 2017 @ 08:43
    Magnus Szatkowski
    Dynamically changing background - Razor and JavaScript
    Hi guys and girls
    I have spent too many hours looking at this code now.. Can anyone help me see what i am doing wrong here.
    I need this piece of code to work - and it is so close - however, the content that I feed to the imageUrls array, doesnt have quotationmarks around them, so the code can't read them as real entries.
        if(Umbraco.TypedContentAtRoot().First().HasValue("vaelgMappe")){
        var mappen = Umbraco.TypedContentAtRoot().First().GetPropertyValue("vaelgMappe");
        var selection = Umbraco.Media(@mappen).Children;
        var urlSelection = new List<string>();
            foreach(var l in selection){
                urlSelection.Add(l.Url);
        var imageUrls = @String.Join(", ", urlSelection.ToArray());
            $(document).ready(function() {
                $("body").backgroundCycle({
                    imageUrls: [@imageUrls],
                    fadeSpeed: 2000,
                    duration: 10000,
                    backgroundSize: SCALING_MODE_COVER
        </script>
    It is live on my development server here: http://dev.kravspecifikation.dk/ - you can see it if you inspect and open the last script of the tag.
    I hope someone can help me!
    Kind regards, Magnus Szatkowski
  • Michael Latouche 504 posts 819 karma points MVP 4x c-trib
    Mar 09, 2017 @ 10:19
    Michael Latouche
    Hey Magnus,
    Maybe you could add the quotes when you add the urls in your urlSelection list? Something like:
            urlSelection.Add(string.Format("'{0}'", l.Url);
    That way they should get through when you build your imageUrls array.
    Hope it helps.
    Michael.
    Mar 09, 2017 @ 10:22
    Alex Skrypnyk
    Hi Magnus
    Did you try to use JavaScriptSerializer?
    JavaScriptSerializer jsSerializer = new JavaScriptSerializer();
    string jsonobj = jsSerializer.Serialize(urlSelection);
    Hope it will help.
    Alex
    Mar 09, 2017 @ 10:38
    Magnus Szatkowski
    Hey Alex and Michael,
    Both good suggestions. However, Alex' code gets this results in this code being printed:
                    imageUrls: [&quot;/media/1002/bg2.jpg&quot;,&quot;/media/1003/bg3.jpg&quot;,&quot;/media/1004/bg4.jpg&quot;,&quot;/media/1005/bg5.jpg&quot;,&quot;/media/1014/nyt1.jpg&quot;],
                    fadeSpeed: 2000,
                    duration: 10000,
    and Michaels code results in:
                    imageUrls: [&#39;/media/1002/bg2.jpg&#39;, &#39;/media/1003/bg3.jpg&#39;, &#39;/media/1004/bg4.jpg&#39;, &#39;/media/1005/bg5.jpg&#39;, &#39;/media/1014/nyt1.jpg&#39;],
                    fadeSpeed: 2000,
                    duration: 10000,
    Do you have any idea if we can get rid of the "&quot" or "'" and print the quoatation mark instead?
    Kind regards,
    Mar 09, 2017 @ 10:41
    Michael Latouche
    101
    Try using Html.Raw:
                imageUrls: [Html.Raw(imageUrls)],
                fadeSpeed: 2000,
    Michael.
    Mar 09, 2017 @ 10:42
    Alex Skrypnyk
    Mangus, try to decode result:
                    imageUrls: [@HttpUtility.HtmlDecode(imageUrls)],
                    fadeSpeed: 2000,
                    duration: 10000,
        </script>
    Mar 09, 2017 @ 10:55
    Alex Skrypnyk
    Extreme programming with Michael and Magnus :)
    Mar 09, 2017 @ 10:56
    Magnus Szatkowski
    Thank you guys!
    I got Michaels code to work, but i am sure your's would work too Alex!
    Thank you so much :)
    Mar 09, 2017 @ 10:59
    Michael Latouche
    @Magnus: Great!
    @Alex: Indeed ;-)
    Michael.
    Mar 09, 2017 @ 11:02
    Alex Skrypnyk
    Guys, have a great day! #h5yr
    Mar 09, 2017 @ 11:04
    Magnus Szatkowski
    I love this community :-D
    Great day to you too! #h5yr
    Mar 09, 2017 @ 11:25
    Michael Latouche
    Thanks and have a great day as well ;-) #h5yr
