  • Lex Godthelp 15 posts 99 karma points
    Mar 21, 2017 @ 15:09
    Lex Godthelp
    Checking if a MACRO gives output
    Hello guys,
    I was wondering if there was any way to check if a certain macro gives an output like so:
    @if(Model.Content.HasValue("expertBijBlog")){
        <div class="hidden-xs hidden-sm hidden-md col-lg-3"><h3>Expert:</h3></div>
    }else if(MACRO HAS VALUE){
        <div class="hidden-xs hidden-sm hidden-md col-lg-3"><h3>Gerelateerd:</h3></div>
    Could anyone help me out?
    ~Lex
    Apr 05, 2017 @ 19:00
    Alex Skrypnyk
    Hi Lex
    You can use RenderMacro method and then check if there some data after rendering, but it's not a good idea. Like that:
    var macroOutput = Umbraco.RenderMacro("myMacroAlias");
    }else if(!string.IsNullOrEmpty(macroOutput)){
    Alex
    Apr 20, 2017 @ 12:10
    Alex Skrypnyk
    Hi Lex
    Did you find out how to do it?
    Do you have something to share with community?
    Alex
    Apr 20, 2017 @ 12:34
    Lex Godthelp
    Hi Alex,
    I was quite busy and completely forgot about this post. I just looked at your solution and it works, except for a minor detail i added:
                    var macroOutput = Umbraco.RenderMacro("Macro");
                    if(Model.Content.HasValue("Valuefield")){
                        <div class="hidden-xs hidden-sm hidden-md col-lg-3"><h3>Do this:</h3></div>
                    }else if(!string.IsNullOrEmpty(macroOutput.ToString())){
                        <div class="hidden-xs hidden-sm hidden-md col-lg-3"><h3>Do That:</h3></div>
    Apr 20, 2017 @ 12:36
    Alex Skrypnyk
    Glad that you solved it, thanks for sharing!
    Have a nice day.
    /Alex
