Hi I've created a profile property of th type Umbraco.DropDownMultiple
No I want that the member can edit this property on his own. I've used the default Edit Profile Macro. Now the profile is displayed as a single line of text.
Therefore I needed to create a new EditorTemplate.
I want to create a multi-select list.
The problem I face is that I can only select 1 value in it; If I select more than 1 value; the value doesn't get correctly updated.
Can you help me? This is my code:
@Html.LabelFor(m => profileModel.MemberProperties[i].Value, profileModel.MemberProperties[i].Name)
List<SelectListItem> cities = new List<SelectListItem>()
new SelectListItem() { Value = "1016", Text= "Washington DC" },
new SelectListItem() { Value = "1017", Text= "Los Angeles" },
List<string> TagIds = profileModel.MemberProperties[i].Value.Split(',').ToList();
MultiSelectList multiselectlist = new MultiSelectList(cities, "Value", "Text",selectedValues: TagIds);
@Html.ListBoxFor(m => profileModel.MemberProperties[i].Value, multiselectlist)
@Html.HiddenFor(m => profileModel.MemberProperties[i].Alias)
When I select only "Washington DC" - it stores the value on my members profile
When I select only "Los Angeles" - it stores the value on my members profile
But when I select both, it doesn't work the way I want.
I've tried several ways to accieve this, but none has helped me so far...
I want the values stored in comma seperated (just like it is stored when editting the member in the backoffice).
In the PartialViewMacroPage "Edit Profile" is this short description:
By default this will render a textbox but if you want to change the editor template for this property you can
easily change it. For example, if you wanted to render a custom editor for this field called "MyEditor" you would
create a file at ~/Views/Shared/EditorTemplates/MyEditor.cshtml", then you will change the next line of code to
render your specific editor template like:
@Html.EditorFor(m => profileModel.MemberProperties[i].Value, "MyEditor")
Where are good examples for this to edit member properties, other than just a single string in a textbox. I'm looking for good examples for editors for "Date", "Date & time", Multi Selectbox, etc.
I'm searching all over the internet but haven't found a decent solution yet.. Can anyone point me in the right direction?
Saving Profileproperties with multiple values
I've tried several ways to accieve this, but none has helped me so far... I want the values stored in comma seperated (just like it is stored when editting the member in the backoffice).
How would you approach this?
To Expand this question:
