  • Joe Dirte 21 posts 163 karma points
    Apr 28, 2017 @ 19:22
    Joe Dirte
    Issues with Macro Rendering
    Hey Our.
    I'm working with some macros right now and am seeing some weird stuff. I hope someone can shed some light on the behavior for me.
    I have this macro.cshtml
     var imageCaption = Model.MacroParameters["imageCaption"];
    <div class="articleHeroContainer">
        <figure>
            <img id="articleHeroImage" src="@Umbraco.Media(Model.MacroParameters["image"].ToString()).Url" />
            <figcaption class="details-font">@Html.Raw(imageCaption)</figcaption>
        </figure>
        <hr />
    It is plugged into an RTE and everything wires up just fine. The problem occurs when the view is rendered this is the output.
        <div class="umb-macro-holder ImageWithCaptionMacro mceNonEditable umb-macro-mce_0">
        <!-- <?UMBRACO_MACRO macroAlias="ImageWithCaptionMacro" image="1310" imageCaption="&lt;p&gt;Photo by Some Guy&lt;br /&gt;Hey here's a caption - outta site.&lt;/p&gt;" /> -->
    <ins>
        <div class="articleHeroContainer"><img id="articleHeroImage" src="/media/1047/supahero.jpg" alt="">
        <p>Photo by Some Guy<br>Hey here's a caption - outta site.</p>
        <hr>
        </ins>
    What exactly am I doing wring here? Should I render a partial inside the macro partial and pass the values over I need?
    Thoughts?
    Apr 30, 2017 @ 20:15
    Joe Dirte
    So I was able to track the issue down to TinyMCE configuration - atleast that's where I am now.
    I've added the following value to the config and refreshed app pools, but still no joy.
    figcaption[class|style],
    May 01, 2017 @ 09:12
    Dave Woestenborghs
    Hi Joe,
    I think you also need to add this one to the tinyMce conifg :
    figure
    And have you checked if the macro outputs correctly when you added it directly to the template. Just to rule out issues with the macro itself.
    Dave
  • Bhawna Jain 16 posts 96 karma points
    May 01, 2017 @ 07:00
    Bhawna Jain
    just for my info,, does your code has given line of code in starting of your macro code file.?
    And u have this output from ur website in html(lke inspecting html) or is it showing something on webpage also?
    May 01, 2017 @ 12:13
    Joe Dirte
    @Dave and @Bhawna
    Yes on both counts.
    The macro uses an RTE as a parameter. If I call the macro by itself in a gridview everything works fine.
    When called inside of an RTE, the macro will render correctly in the RTE, but will loose any non P tags that were included when the macro RTE param was authored.
