  • Arindam 11 posts 91 karma points
    May 12, 2017 @ 08:29
    Arindam
    Need Carousel in Header
  • David Houghton 33 posts 108 karma points
    May 12, 2017 @ 08:46
    David Houghton
    Add a picker on the homepage node for selecting the images you want in the carousel.
    On the homepage view put
    var pickerAlias = "yourPickerAliasHere";
    var hasCarouselImages = Model.Content.HasProperty(pickerAlias)  && Model.Content.HasValue(pickerAlias);
    This evaluates to true / false.
    Now use like:
    @if(hasCarouselImages){
                 @Html.Partial("shared/_header-carousel");
    In the partial build up your carousel. Just make sure that when you loop over the added images, do a test to see if the image does not equal null.
    There are so many carousels out there continuing from this point will be a touch difficult but a carousel I very much like because of its ease of implementation, responsiveness and available settings is slick carousel - http://kenwheeler.github.io/slick/ give it a shot and if you need any help setting up id be happy to help you out.
    May 12, 2017 @ 14:41
    Arindam
    Hi David ,thanks for your valuable time . I will be revert back once applied the same.
