  • Arindam 11 posts 91 karma points
    May 15, 2017 @ 06:37
    Arindam
    Custome style issue
    I am rendering menu using partials but my custom css isn't effected the menu . Its taking by default bootstrap css .
    Please help and all help will be highly appreciated .
    May 15, 2017 @ 06:47
    Dennis Aaen
    Hi Arindam,
    You you please make sure that your CSS file with the custom CSS are the one that are being load after the default bootstrap CSS.
    Hope this helps as a start.
    /Dennis
    May 15, 2017 @ 06:51
    Arindam
    Hi ,Dennis Aaen
    I am providing the css order here
    <!-- Custom styles for this template -->
    <link href="~/css/bootstrap.min.css" rel="stylesheet">
    <link href="~/css/font-awesome.css" rel="stylesheet">
    <link href="~/css/carousel.css" rel="stylesheet">
    <link href="~/css/style.css" rel="stylesheet">
    <link rel="stylesheet" href="~/css/owl.carousel.min.css">
    <link rel="stylesheet" href="~/css/owl.theme.default.min.css">
    first one is bootstrap and style.css is our custom css
    Please help isnt work in this way .
    May 15, 2017 @ 07:18
    Dennis Aaen
    Hi Arindam,
    Okay then you should be sure that you are taget your custom CSS sectors with a higher specificity than the default Bootstrap once.
    Try to see this https://www.smashingmagazine.com/2007/07/css-specificity-things-you-should-know/#specificity-hierarchy
    Hope this helps,
    /Dennis
