Normally the “useIfEmpty” field if used, shows the property when the value is empty – such as
This would place the metaTitle in this area, and if that was blank – it would use the @pageName property.
This doesn’t work any longer in Umbraco 7 – Will this be fixed?
What it does now, is just traverse up the tree until it finds a page that has that property filled out (metaTitle) and shows that one. It never shows the page name.
This is not how it is suppose to function and really plays havoc with SEO and people that aren't aware may be loosing rankings/traffic due to this.
keeps stripping out the code :: I am not using any partial view or macro to view - just a basic Umbraco page field with the normal code like this :: [<umbraco:Item field="metaTitle" useIfEmpty="pageName" runat="server">]. It was working for years, but since upgrading to 7 - doesn't seem to work any longer. Thanks.
Yes it should - thus why I am submitting this to the forum to see if others are having the same issues with this. I understand that it isn't in the "List of Breaking Changes" - but many things do break as you create new functionality and change existing functions. Looking for anyone else having this issue and if there is a fix for this. Thanks.
This feature also is broke on Rich Text editors. I have noticed it broke in some templates, but just fixed it to make work. However, it is still a bug that should be fixed.
As well, do you have a non-razor fix for this - we just use the normal webforms with the property and not the razor templates or MVC.
Will that be fixed in the 7.6.3 - or just the razor fix?
I think the fix in 7.6.3 is for both razor and masterpages.
There's many bugs that should be fixed, but it's doubtful that they ever will be, our main focus is on fixing MVC related bugs, WebForms is obsolete and no longer something we can help a lot with. Feel free to send us a pull request though, we'll happily look at it.
useIfEmpty NOT WORKING - major SEO Flaw
Hi Wade
Can you show the source code of your partial?
Alex
It should work, there are not so many changes in Umbraco 7.6
List of breaking changes - https://our.umbraco.org/documentation/getting-started/setup/upgrading/760-breaking-changes
Oh it's been (accidentally!) broken for a very long time, it looks like it broke in 7.3.2 already.
This should be fixed in 7.6.3 - http://issues.umbraco.org/issue/U4-9971
You'll be able to do:
@Umbraco.Field("metaTitle", altText:"[#pageName]")to do what you want to do.For now, you can use:
And then later on you can use the
metaTitlevariable, for example:<meta property="og:title" content="@metaTitle" />This feature also is broke on Rich Text editors. I have noticed it broke in some templates, but just fixed it to make work. However, it is still a bug that should be fixed.
Thanks.
More info on WebForms support here: http://issues.umbraco.org/issue/U4-9930#comment=67-36838
7.6.3 is out now, if you would like to give it a go!
We are upgrading this week, thanks for the fix - we will try it out let you know if it is all good.
