  • Shakib 32 posts 134 karma points
    Jun 12, 2017 @ 10:42
    Shakib
    Problem Retrieving Media Url in Umbraco 7.6.3
    i just updated my umbraco to 7.6.3, but i encounter with this error in my views that i use .Url property like below:
    @Umbraco.Media(CurrentPage.photoMedium).Url
    how can i retrive media url in this new version ??
    Jun 12, 2017 @ 10:46
    Alex Skrypnyk
    Hi Shakib
    Since version 7.6 Umbraco has Property Value Converters in the core, so you can access your Media like:
            var typedMediaPickerSingle = Model.Content.GetPropertyValue<IPublishedContent>("photoMedium");
            if (typedMediaPickerSingle != null)
                <p>@typedMediaPickerSingle.Url</p>
    Also, you can disable this functionality in umbracoSettings.config EnablePropertyValueConverters set to false.
    Hope it will help you.
    Alex
    Jun 12, 2017 @ 13:02
    Shakib
    this code returns me null, but in the backoffice i can see that one image selected for "photoMedium" property and every thing is ok.
    i dont know where is the problem.
    Jun 12, 2017 @ 13:20
    Shakib
    when i disable Property Value Converters functionality every thing looks good.
    but i guess something is wrong with this Property Value Converters.
    another question i have is that why mediapicker is obsolete?what is the replace for that ??
    Jun 12, 2017 @ 13:33
    Alex Skrypnyk
    Hi Shakib
    mediapicker2 is replacement for old mediapicker
    You can still use mediapicker with version 7.6, but in future it will be totally replaced by mediapicker2
    The difference between mediapicker and mediapicker2, how it stores the media id. First one works with 4 digits id, second one works with udi ids, it's more reliable and flexible way.
    Alex
  • Paul Wright (suedeapple) 277 posts 704 karma points
    Jun 12, 2017 @ 14:18
    2
    @CurrentPage
    Is "dead" too :-), so keep things as @Model......
  • Paul Seal 524 posts 2890 karma points MVP 7x c-trib
    Jun 12, 2017 @ 16:02
    Paul Seal
    See my updated blog post which at the top shows how to get it for 7.6x and after that the original for 7.5x and below.
    http://www.codeshare.co.uk/blog/how-to-get-the-file-path-of-a-media-item-in-umbraco/
    Kind regards
    Paul
    Jun 13, 2017 @ 06:12
    Shakib
    thanks every one for helping me.
    it was really helpful.
