I have a new site where part of my navigation is anchor tags on the home page, and part is child pages. I can't seem to figure out how to get the URL to the root from the child pages, so that it directs back to the home page/anchor.
the @Model.Content.Site.Url throws this error:'Umbraco.Web.PublishedContentExtensions.Site(Umbraco.Core.Models.IPublishedContent)' is a 'method', which is not valid in the given context
and, using
<a href="/#opportunity">Opportunity</a>
works fine on the root page, but on a child page it doesn't navigate it back to the root page, it just sits there.
@using umbraco.MacroEngines;
@{ var home = CurrentPage.Site(); }
@if (home.Children.Any())
@* Get the first page in the children *@
var naviLevel = home.Children.First().Level;
@* Add in level for a CSS hook *@
<ul id="js-navigation-menu" class="navigation-menu">
@*Static anchor links with no pages*@
<li><span><a href="@Umbraco.TypedContentAtRoot().First().Url#opportunity" class="anchor-link">Opportunity</a></span></li>
<li><span><a href="@Umbraco.TypedContentAtRoot().First().Url#empowering-philanthropy" class="anchor-link">Empowering Philanthropy</a></span></li>
<li><span><a href="@Umbraco.TypedContentAtRoot().First().Url#who-we-are" class="anchor-link">Who we are</a></span></li>
@* For each child page under the home node *@
@foreach (var childPage in home.Children.Where("umbracoNaviHide != true"))
if (childPage.Children.Any())
<li class="has-child">
@if (childPage.DocumentTypeAlias == "LandingPage")
<span><a href="@childPage.Url" class="@(childPage.IsAncestorOrSelf(CurrentPage) ? "selected" : null)">@childPage.Name <i class="fa fa-angle-down"></i></a></span>
@childPages(childPage.Children)
else
<span><a href="@childPage.Url" class="@(childPage.IsAncestorOrSelf(CurrentPage) ? "selected" : null)">@childPage.Name</a></span>
</li>
else
<li>
</li>
</ul>
@helper childPages(dynamic pages)
@* Ensure that we have a collection of pages *@
if (pages.Any())
@* Get the first page in pages and get the level *@
var naviLevel = pages.First().Level;
<ul class="submenu">
@foreach (var page in pages)
<li>
<a href="@page.Url" class="@(page.IsAncestorOrSelf(CurrentPage) ? "selected" : null)">@page.Name</a>
</li>
</ul>
You may want to look at some of the menu plugins that are out there if you want to make it easy on yourself. We use this one quite often: https://github.com/vadikom/smartmenus
Also, I'm not sure why, if you're wanting to navigate to a new page, you need to close the menu? Wouldn't it just be closed when you land on the new page?
Using anchor links in nav menu url issues
I'm using razor and umbraco 7.6
Thanks!
Hi Bryanne
Did you mean url part after "#" as anchor?
Umbraco doesn't handle this part of url, it's client side totally. You have to use some js script for doing it.
Alex
Hi Bryanne,
In your code that generates the menu, you should be able to use something like:
This should get the root node of your site so you can append it your anchor entries when creating the menu.
Alternatively, you could just append "/" before your anchors when you create the menu.
Nik
'Umbraco.Web.PublishedContentExtensions.Site(Umbraco.Core.Models.IPublishedContent)' is a 'method', which is not valid in the given contextand, using
Hi Bryanne,
You can also do it like this:
Hope this helps!
Amir
Is there an error in the Chrome developer console when you click the link?
Are you using AngularJS or Angular?
There are no errors. Im using Razor/mvc, no angular etc.
When using
i get this HTML output
Which works fine on the home page, but from a child page it still doesnt' navigate anywhere
Im working in a local dev environment if that matters
That's really bizarre...are your child pages underneath your homepage? Mind uploading a screenshot of your content tree?
This is my content tree.
This is my menu code:
and this is how the HTML renders
That looks normal and I just tried the code for your nav and it worked fine for me.
Are you sure there isn't something with the JS for your menu that's catching the anchor links and preventing navigation?
As a test, you may want to just remove that javascript and see if navigation occurs as expected.
-Amir
I was actually just investigating the JS myself.
Seems there's something in here thats breaking it.
What this is, is a function to open my mobile menu, and then, when clicking the anchor links, to close said mobile menu.
Ahhh. So this "e.preventDefault();" prevents the default action (navigating to the target) of the anchor tag from occurring :)
You'll likely want to rework your js logic.
-Amir
Yup. Unfortunately i'm not a JS guru, so might take me some time. If you have any tips that would be great!
Hope this helps,
Amir
There's 3 links that are anchors, so those need to close the menu, and there's 2 that are actual pages.
General guidance would be to add a class to the toggle links only and only apply your preventdefaut method / toggle logic to those.
Away from my desk or would write something up for you.
Thanks! working that thru now
