  • Prisha 16 posts 86 karma points
    Jun 17, 2017 @ 08:26
    Prisha
    Issue with using Umbraco in Sub-folder / Virtual Directory?
    Hi Friendly Community,
    I am using Umbraco in virtual directory in IIS and when I save partial view macro I get error, also application name is appended(indicated with the red box). I don't get this problem when I use IISexpress. Screen shoot of issue: enter image description here
    So far I read this and this and read this but none of them really describe the problem I am facing. Please help me !!!!
  • Gary 1 post 71 karma points
    Apr 04, 2018 @ 06:53
    Gary
    hi all, i also get above issue. any help please?
  • Eugene 1 post 71 karma points
    Apr 19, 2018 @ 02:18
    Eugene
    I have the same issue. There is no slash between the virtual directory name and partial view folder name. Does anyone know how to fix this ?
    An error occured File '/UmbracoTest774StandardPageComponents/MyProduct.cshtml' is outside this filesystem's root.
  • Bernz 2 posts 72 karma points
    Oct 03, 2018 @ 08:50
    Bernz
    Any solution with this problem is so much appreciated. Same problem here. Thanks for any response.
    Oct 08, 2018 @ 11:34
    Bernz
    After some front-end debugging, I come up with some workaround, though it's untidy I think.
    I modified "save" function in "\Umbraco\Js\umbraco.resources.js" to:
      save: function (codeFile) {
                            codeFile.virtualPath = "~/Views/MacroPartials/" + codeFile.id;
                                 return umbRequestHelper.resourcePromise($http.post(umbRequestHelper.getApiUrl('codeFileApiBaseUrl', 'PostSave'), codeFile), 'Failed to save data for code file ' + codeFile.virtualPath);
    I added line:
    Perhaps there's something wrong with back-end parsing of macro partialview file fullPath in server-side. Not sure though.
    Hope this helps. :)
  • andrew van vlack 3 posts 95 karma points
    Apr 27, 2019 @ 11:33
    andrew van vlack
    I fixed this in an Umbraco 7.14 installation by making the following change:
    Running in a Virtual Directory IIS:
    codeFile.virtualPath = codeFile.virtualPath.replace("/virtualdirectory", "");
