I'm running Umbraco 7.5.11 and I'm looking for a way to provide our UX/content editors with a means to input some variable javascript to a page for A/B testing purposes. (using VWO)
The script will be unique for each page they want to test and should only be active for that page.
So far we've run one test on a single page and the javascript has been placed directly in to a template, but is there a way I could create a data type which would allow them to input their custom javascript from VWO and make it active/inactive, without them having access to templates?
As it turns out, I just learned after I posted this that we may not have to implement this functionality for our content editors, but it's worth keeping a note of your recommendation in case we do, I'll have a play around anyway.
I'll also take a look at that personalisation package, as this is on the horizon for us too.
Method for inputting variable javascript
Looking for some advice on this one...
Thanks Stuart
Hi Stuart
You can use simple Multiline Textstring property for inserting page specific scripts on the page.
Just add new property to document type, and render it in the template.
Your editors will not be able to change templates, just work with this field, add new js or edit it on each page.
Alex
Also, please have a look at this package, it can help - https://our.umbraco.org/projects/website-utilities/personalisation-groups/
Thanks for taking the time to reply Alex
Thanks again,
Stuart
You are welcome, Stuart
Ask if something, have a great day!
Alex
