  • sahadev 18 posts 145 karma points
    Jul 03, 2017 @ 13:09
    sahadev
    Convert MVC razor code into xslt code
    i'm new in xslt kind of things please help me convert below code into xslt format
        //get all children of type 'slide_item'
        var slides = @CurrentPage.Children.Where("DocumentTypeAlias == \"slide_item\"");
    <div class="slider">
        @foreach (var slide in @slides) {
          //Fallback: Ignore slide when no image was uploaded,
          //else the slide would cause a server error.
          if(@slide.image != null) {
            var image = Umbraco.Media(@slide.image);
            <div class="slide">
                <img alt="@slide.name" src="@image.Url">
    Jul 03, 2017 @ 14:10
    Alex Skrypnyk
    Hi Sahadev
    Why do you need to convert this pretty code to XSLT?
    Alex
    Jul 04, 2017 @ 04:41
    sahadev
    Hi Alex ,
    First of all thanks for your response
    i want to convert it because i'm using Umbraco 6.1.6 with webforms so i think razor not supported in it that's why i want to convert in into xlst
    thanks
    sahadev
    Jul 04, 2017 @ 08:20
    sahadev
    its working in umbraco 6 also
