i am in step 13. When running the site i get the following error:
> The view found at '~/Views/Home.cshtml' was not created.
> Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more
> information about the error and where it originated in the code.
> Exception Details: System.InvalidOperationException: The view found at '~/Views/Home.cshtml' was not created.
> Source Error:
> An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of
> the exception can be identified using the exception stack trace below.
> [InvalidOperationException: The view found at '~/Views/Home.cshtml'
> was not created.]
> System.Web.Mvc.BuildManagerCompiledView.Render(ViewContext
> viewContext, TextWriter writer) +253
> Umbraco.Core.Profiling.ProfilingView.Render(ViewContext viewContext,
> TextWriter writer) +113
> System.Web.Mvc.ViewResultBase.ExecuteResult(ControllerContext context)
> +291 System.Web.Mvc.ControllerActionInvoker.InvokeActionResult(ControllerContext
> controllerContext, ActionResult actionResult) +13
> System.Web.Mvc.ControllerActionInvoker.InvokeActionResultFilterRecursive(IList`1
> filters, Int32 filterIndex, ResultExecutingContext preContext,
> ControllerContext controllerContext, ActionResult actionResult) +56
> ControllerContext controllerContext, ActionResult actionResult) +420
> System.Web.Mvc.ControllerActionInvoker.InvokeActionResultWithFilters(ControllerContext
> controllerContext, IList`1 filters, ActionResult actionResult) +52
> System.Web.Mvc.Async.<>c__DisplayClass2b.<BeginInvokeAction>b__1c()
> +173 System.Web.Mvc.Async.<>c__DisplayClass21.<BeginInvokeAction>b__1e(IAsyncResult
> asyncResult) +100
> System.Web.Mvc.Async.WrappedAsyncResult`1.CallEndDelegate(IAsyncResult
> asyncResult) +10
> System.Web.Mvc.Async.WrappedAsyncResultBase`1.End() +49
> System.Web.Mvc.Async.AsyncControllerActionInvoker.EndInvokeAction(IAsyncResult
> asyncResult) +27
> System.Web.Mvc.Controller.<BeginExecuteCore>b__1d(IAsyncResult
> asyncResult, ExecuteCoreState innerState) +13
> System.Web.Mvc.Async.WrappedAsyncVoid`1.CallEndDelegate(IAsyncResult
> asyncResult) +29
> System.Web.Mvc.Controller.EndExecuteCore(IAsyncResult asyncResult) +36
> System.Web.Mvc.Controller.<BeginExecute>b__15(IAsyncResult
> asyncResult, Controller controller) +12
> asyncResult) +22
> System.Web.Mvc.Controller.EndExecute(IAsyncResult asyncResult) +26
> System.Web.Mvc.Controller.System.Web.Mvc.Async.IAsyncController.EndExecute(IAsyncResult
> asyncResult) +10
> System.Web.Mvc.MvcHandler.<BeginProcessRequest>b__5(IAsyncResult
> asyncResult, ProcessRequestState innerState) +21
> asyncResult) +29
> System.Web.Mvc.MvcHandler.EndProcessRequest(IAsyncResult asyncResult)
> +28 System.Web.Mvc.MvcHandler.System.Web.IHttpAsyncHandler.EndProcessRequest(IAsyncResult
> result) +9
> System.Web.CallHandlerExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute()
> +9765045 System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously) +155
When i log into backend i see all the content nodes, media etc...
When trying to enter one of the content nodes i get the following error:
The file "~/Views/Master.cshtml" could not be rendered, because it does not exist or is not a valid page.
Exception Details: System.Web.HttpException: The file "~/Views/Master.cshtml" could not be rendered, because it does not exist or is not a valid page.
I think i have failed in step 10, but dont know much regarding config files. Anyone that can help me?
Hey, thanks for the reply!
The config setting was: PureLive
After setting it to: value="Dll" i get the following YSOD:
Compilation Error
Description: An error occurred during the compilation of a resource required to service this request. Please review the following specific error details and modify your source code appropriately.
Compiler Error Message: CS0234: Typen eller navneområdenavnet Home finnes ikke i navneområdet Umbraco.Web.PublishedContentModels (Kanskje du mangler en samlingsreferanse?)
Source Error:
Line 40: Line 41: Line 42: public class
_Page_Views_Home_cshtml : Umbraco.Web.Mvc.UmbracoTemplatePage<ContentModels.Home> { Line 43: Line 44: #line hidden
Source File: c:\Users\Stian\AppData\Local\Temp\Temporary ASP.NET Files\vs\248dbc68\cab1c38a\App_Web_home.cshtml.65a2d1ee.jakmxzmv.0.cs Line: 42
migrating to Umbraco Cloud - problems. View was not created...
I am trying to migrate a existing site to Umbraco Cloud using the following guide: https://our.umbraco.org/documentation/Umbraco-Cloud/Deployment/Migrate-Existing-Site/
When i log into backend i see all the content nodes, media etc... When trying to enter one of the content nodes i get the following error: The file "~/Views/Master.cshtml" could not be rendered, because it does not exist or is not a valid page.
Hi St
Can you check "ModelsBuilder" config setting?
Alex
Hey, thanks for the reply! The config setting was: PureLive
In other words:
The type or namespace name Home does not exist in the Umbraco.Web.PublishedContentModels namespace. (Maybe you're missing a collection reference?)
Can you go to the development section of Umbraco and regenerate Models Builder Models?
Thanks for the help! I regenerated the models builder models. Now i get no YSOD, now i get the Welcome to your umbraco installation site.
When logging inn i can see all the content nodes. I can preview them (and they show properly)
, but not publish.
Any idea how to resolve?
Truly said didn't see it before, usually if content transferred successfully - it's published.
I republished the main node, and suddenly everything seems to be working.
Glad that problem has been solved!
