  • Rayyan 46 posts 238 karma points
    Jul 19, 2017 @ 11:43
    Rayyan
    Display images from directory
    Hello Everyone, I want to display images from specific directory in the server, I have got this code in the partial view but didn't work, any idea please?
        string folderPath = Server.MapPath("~/media");
        string[] files = Directory.GetFiles(/1039);
            @foreach (string item in files){
                <img src="/media/@Path.GetFileName(item)"/>
    Jul 19, 2017 @ 11:47
    Alex Skrypnyk
    Hi Rayyan
    Try this code:
        string[] files = Directory.GetFiles(folderPath + "/1039");
        <img src="@item"/>
    The question is why do you need to show media images .net api? You can do it with Umbraco helper.
    Alex
    Jul 19, 2017 @ 11:55
    Rayyan
    Hi Alex, I really appreciate your help. I'm going with this way because I have hundreds of folders and i need to get the images from each folder dynamically.
    It seems the code you suggest is working, but I have a problem with the image PATH, please advise;
    E:\web\domain.com\media/1039\homepro.jpg
    Thank you very much
    Jul 19, 2017 @ 11:58
    Alex Skrypnyk
    Sorry, this code should work:
        <img src="/media/@Path.GetFileName(item)" />
    Jul 19, 2017 @ 12:14
    Rayyan
    Working perfectly :) Thanks a million Alex!
         <img src="/media/1039/@Path.GetFileName(item)" />
    Jul 19, 2017 @ 12:15
    Alex Skrypnyk
    You are welcome, Rayyan.
    But be aware that it's not a right way to show the image, imagine if somebody will change this image from Umbraco backend?
    Jul 19, 2017 @ 12:23
    Rayyan
    What do you suggest for my case, having hundreds of folders and I need to display each folder images in specific page?
    Jul 19, 2017 @ 15:24
    Alex Skrypnyk
    2
    The best case will be to use media picker on the page, and select folder for each page and render with Umbraco helper.
    Jul 19, 2017 @ 16:28
    Rayyan
    Thank you Alex, I will consider that in the next version. And for the same code I have tried to add the folder name from PropertyValue but it dosen't work, could you please check the following;
        string folderPath = Server.MapPath("/media");
        string[] files = Directory.GetFiles(folderPath + "/@Model.Content.GetPropertyValue("placeID")");
        <img src="/media/@Model.Content.GetPropertyValue("placeID")/@Path.GetFileName(item)" />
    Am I doing it in the wrong way?
    Jul 19, 2017 @ 22:02
    Alex Skrypnyk
    Hi Rayyan
    What is placeID property? How did you store it in Umbraco?
    Alex
    Jul 19, 2017 @ 22:05
    Jul 19, 2017 @ 22:16
    Alex Skrypnyk
    You are welcome!
    Have a nice evening.
    Jul 19, 2017 @ 22:18
    Rayyan
    Your help made my day! Have a nice evening you too.
    Jul 20, 2017 @ 11:07
    Rayyan
    Hi Alex,
    Sorry for bothering you, but I have a question...
    Is there a way to control the number of the items that the code get from the folder?
    Something as below;
     <img src="/media/@Model.Content.GetPropertyValue("placeID")/@Path.GetFileName(item) [6 Items Max] " />
    Many thanks
    Aug 01, 2017 @ 10:42
    Alex Skrypnyk
    Hi Rayyan
    Did you solve the issue? Can you share with out community?
    Alex
    Aug 01, 2017 @ 11:36
    Aug 01, 2017 @ 11:37
    Alex Skrypnyk
    Hi Rayyan,
    Thanks for sharing, is it working for you?
    Alex
    Aug 01, 2017 @ 11:45
    Rayyan
    Yes, perfectly!
    Jul 20, 2017 @ 11:11
    Alex Skrypnyk
    Hi Rayyan
    Of course you can do it:
    string[] files = Directory.GetFiles(folderPath).Take(6).ToArray();
    Alex
