  • Dmitriy 168 posts 588 karma points
    Jul 26, 2017 @ 11:13
    Dmitriy
    TextString and others property editors render a lot of spaces
    Hello. For some reason different text property editors (textstring, textarea) render a lot of spaces before and after string.
    For example:
    <p>
        @Model.Content.SomeText
    </p>
    renders
    "        lorem ipsum     "
    Why and how to fix? Looks like view renders with code-spaces that using for good look of code.
  • Alex Skrypnyk 6182 posts 24283 karma points MVP 8x admin c-trib
    Jul 26, 2017 @ 11:14
    Alex Skrypnyk
    Hi Dmitriy
    First of all remove line breaks:
    <p>@Model.Content.SomeText</p>
    Second - check Umbraco property value, does it contain extra spaces or no.
    Alex
    Jul 26, 2017 @ 11:31
    Dmitriy
    Hi, Alex.
    It helped, but how to keep code good formating and proper render in same time?
    Jul 26, 2017 @ 11:38
    Alex Skrypnyk
    What is the problem with this code?
    If you want another formatting and no extra white spaces at the same time, you can use some package or custom code.
    I didn't try this package - https://our.umbraco.org/projects/developer-tools/html-minifier/
    But it looks like what you need.
    Alex
    Jul 26, 2017 @ 11:42
    Dmitriy
    No problem with that code, but if I want to do something complicated like loops or other difficult murkup, that code become unreadeble.
    I'll take a look on this package, thank you.
    Jul 26, 2017 @ 11:48
    Alex Skrypnyk
    You are welcome, please share with the community your results.
