  • MaxD23 5 posts 72 karma points
    Aug 05, 2017 @ 15:07
    MaxD23
    Umbraco.Core.Models.PublishedContent.PublishedContentEnumerable' does not contain a definition for 'Split'
    I successfully upgraded a site from 7.2.6 to 7.5.14 but when upgrading to 7.6.0 I have a breaking change and cannot figure out where to look. I have been looking on this the last 2 days so help is definitely required.
    The Homepage use Owl Carousel and the error message is :
    @if (CurrentPage.HasValue("carouselItems")) {
       var itemIds = CurrentPage.CarouselItems.Split(new string[] { "," },
       StringSplitOptions.RemoveEmptyEntries);
       var carouselItems = Umbraco.Media(itemIds);
    Thank you
  • Damien Green 72 posts 134 karma points
    Feb 15, 2018 @ 13:06
    Damien Green
    Hi Max,
    I've just encountered exactly the same issue after upgrading one of my sites. The solution is to explicitly add a .ToString() like so:
    @if (CurrentPage.HasValue("carouselItems")) { var itemIds = CurrentPage.CarouselItems.ToString().Split(new string[] { "," },
    StringSplitOptions.RemoveEmptyEntries); var carouselItems = Umbraco.Media(itemIds);
    I'm surprised that no one else has come back to you about this, it's a pretty major breaking change.
    hope this helps,
    Damien
